carb base gasket
mad dog
ct
hello FABO, putting the final pieces together on my 1970 340 stock rebuild, the carb is next to go on but wondering if you guys could recommend a base gasket that the carb would sit on.
The intake is an original 1970 cast iron piece with the 4 openings and the carb is a Carter .
I would like a gasket that will help with heat soak but not so tall that it will affect my linkages, can someone help with a link... thanks Rich
Thanks Steve, I just placed an order with Summit.
