streetkit
Carter AVS 4bbl Carburetor. 4640sa, 1969 440 Magnum with AC. Will need to be rebuilt and also a little bit of work. The little screws that hold the secondary door onto the shaft snapped when being removed. All the parts (shaft, spring, air door)are included, but you will need to get the broken stubs out and use new screws.
$99 shipped to your door anywhere in the USA
Located in CA
Located in CA
