[WANTED] Carter BBD 6150s
domdart
Johnstown, PA
I am looking for a carb for my 72 D100 318. It has a 0-2378 on it now leaving the vacuum and cannister lines with nowhere to connect them. The correct carb I need is the BBD 6150s.
Thanks FABO.
If I could get a core and a rebuild kit and then bolt it on the truck I would be interested. I don't want to be searching for connectors and linkages and stuff before the install.
Here is an un-tagged BBD from a 73 pick-up application. see the broken plastic vent you asking about. nice core. I have other link pieces somewhere.
