Carter M6270
CRUZE 418
Illinois
Has anyone run an M6270 Carter fuel pump without a pressure regulator? Seem to be pretty limited on mechanical fuel pumps unless you want a chrome Holley or Edelbrock. I am running a Six pack and am trying to stay with stock fuel lines, would rather NOT have to use a regulator.
I'm not sure which model that is if it's the muscle car pump I run that pump with 3/8 line on my six pack no need for a regulator. I'm not a fan of the 5/16 factory line. Six pack needs volume not pressure.
Okay I just looked it up that's the strip pump I used to run that pump with my T quad for years with no regulator and no problems but have never run it with my six pack.
I'm just taking things in front off for an oil leak, and see that my fuel pump is a Carter, it has no M 6270 on it, but I will bet that's what it is. It came with the car. I have a reason for wanting to replace it, the car runs fine with it. Double checking something, plus cosmetics. The Six pack is the problem, but that's another bug, I am getting closer!
So I have my answer, have an M6270 on backorder.
Thank you for answering KO.
That pump is listed in my Carter catolog, which is pretty old. Listed as a 'Super Pump' , 7.5 psi output pressure.
