[SOLD] CENTER FORCE DF 269739 KIT DUAL DISC
couper 340
maryland
Just removed less than 100 miles on it . same reason as other parts i sold going back all stock. center force DF 269739 kit all street mile on this . 23 spline disc 10.4'' just broken in no wear on pressure plate very lite marks from sitting . Can use stock bearing with it . selling for $350.00 shipped . new is $539.00 AT JEGS. All so selling 130 tooth 1045 billet steel fly wheel also 100 mile on it no wear for 10.5 clutch came from 440 source it is internal balance . also came with a weight for a cast 440 crankshaft if you need it for a cast 440 only pt# 113-1014 selling for $100 + 25 shipping , new $150.00 and yes i payed shipping when i got it . Also have Lakewood bell housing with shield must me pick up will not ship. $ 325.00 does not come with fork
This clutch set up is small block 340 and bell housing fly wheel is small block or big block 130tooth
single disc dual sides
All clutch discs have 2 sides. A dual disc has 2 discs and a floater plate. You just have a Centerforce Dual Friction not a dual disc. The Dual Friction discs have different material on each side.
