Center link and hemi swap
cu440da
Cottage Grove, MN
Is there an issue with these swaps using the small block center links, or is the Big Block center link needed for oil pan clearance?
EDIT- sorry, I think I meant slant 6 vs. V8. Been away from the A body too long.
I'll be using the Milodon mid sump pan if it matters.
Brain fart. Whichever one has more drop for oil pan clearance. Is it needed or can I roll on with whatever I happen to have?
I had a 74 Swinger. Og /6. Used the og front K and suspension. Conversion mounts for 408. Then did gen 3 deal. Had to switch K member to actual V8 K. Kept EVERYTHING else. No issues.
In A bodies, I think after 1965....a center link was a center link, no matter what motor. I used a Milodon pan to put a 5.7 Hemi into a 70 Duster. I used a 73 and up V8 spool mount k frame, and there was plenty of clearance between the pan and center link.
