Champion Alum Radiators, anyone?
Heating / Cooling / AC
  1. dusterdoug
    dusterdoug Well-Known Member
    995
    145
    Sep 26, 2007
    Tracy, CA
    Local Time:
    7:29 PM
  2. sireland67
    sireland67 FABO Gold Member FABO Gold Member
    9,780
    4194
    Oct 27, 2010
    WV
    Local Time:
    10:29 PM
    I have a champion in my duster, it fits great and cools extremely well considering I don't run a shroud on it.
  3. duster731
    duster731 young gun
    1,460
    28
    Mar 30, 2010
    Venus Texas
    Local Time:
    7:29 PM
    ^^ same here no shroud fits great and does its job.. Love it
  4. seabee
    seabee FABO Gold Member FABO Gold Member
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    7:29 PM
    Used one for 5yrs. No problems. 2 row, 22"
  5. mopowers
    mopowers Well-Known Member
    6,219
    3438
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    7:29 PM
    Anyone ever mount a 26" Champion radiator to a smaller 22" opening radiator support??? Any issues to worry about"
  6. dusterdoug
    995
    145
    Sep 26, 2007
    Tracy, CA
    Local Time:
    7:29 PM
    Good question! I have the 22" opening and would rather not cut it.
  7. adamp
    adamp Well-Known Member
    207
    29
    Sep 10, 2014
    Merced, Ca
    Local Time:
    7:29 PM
    Mine just came in yesterday.... My buddy has ran one in his impala for 1.5 years now (runs it hard all the time) with no issues... runs cool and everything is great. He is the reason I went with champion over all the other ebay radiators.
    [​IMG]
  8. dusterdoug
    995
    145
    Sep 26, 2007
    Tracy, CA
    Local Time:
    7:29 PM
    Good news...thanks! I should have asked the question in original post:
    What motor and how much power are you cooling?
  9. daredevil
    daredevil Well-Known Member
    10,983
    150
    May 19, 2007
    S/w Houston
    Local Time:
    9:29 PM
    I tried a cc375 in my coronet and it would steadily creep to hot even down the road. Swapped out for a griffin and problem gone. You get what you pay for.
  10. ECPJT
    ECPJT Member
    18
    0
    Jan 12, 2015
    Charlotte, NC
    Local Time:
    10:29 PM
    The same money or less than some Champions, and you can get a better warranty
  11. twayne24365
    twayne24365 Well-Known Member
    1,550
    363
    Jun 18, 2013
    Maryland
    Local Time:
    9:29 PM
    Have one in a 65 coronet with a pretty stout 440, never got above 180*, after 3 years it started leaking on both corners on the drivers side, replaced it with another one andits been great. Its a 26" 3 row
  12. straightlinespeed
    straightlinespeed Sometimes I pretend to be normal FABO Gold Member
    10,609
    4254
    Oct 21, 2012
    Uvita, Costa Rica
    Local Time:
    9:29 PM
    I've got 22" Champion in my car. Here are my likes and dislikes
    Likes: Car runs nice and cool. Good cheap replacement that functions well.
    Dislikes: Only top two bolt holes lined up, had to redrill the lowers. Shroud nut inserts came right out, had to replace with my own.
    Overall Im very happy with the radiator. Works and does what it is suppose to! I would buy one again for the little bit of hassle I had to do to it.
  13. Propwash
    Propwash FBBO Cat
    84
    9
    Jan 8, 2011
    The Muppet Show
    Local Time:
    9:29 PM
    I have a 26" 3 row Champion radiator & factory 26" shroud cooling the 512 stroker in my Roadrunner. Still has the 22" opening. Car runs cool as a cucumber, in all conditions.
    Don't know on the fit up for an A-Body, but in a B-Body you need to use the factory mount holes on the driver side, and then drill the holes on the passenger.
    Hope it helps.
  14. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    11,920
    6988
    Nov 28, 2008
    NorCal
    Local Time:
    7:29 PM
    I run a Champion CC374 in my Duster. That's a 26" 3 core that is listed for B/E bodies. The Duster had a 22" radiator in it originally and still has the 22" opening in the shroud. All I did to mount the radiator was tack weld a couple of nuts onto the front of radiator support like the factory did for the 22" radiator.
    There's no problem putting a 26" radiator in front of the 22" shroud opening. In fact, it will still cool better like that than a 22" radiator would. You still have more surface area, and that surface area is still exposed to air that's going to be cooler than the radiator. Yes, the radiator would probably be a little more efficient if you opened up the radiator shroud so that the entire core was exposed, but we're not talking about much.
    I run my Champion CC374 with a Ford Contour electric fan set up. I swapped to that because the car ran so COLD with the mechanical fan that it would take forever to just warm up to operating temperature. How's that for a problem to have? Anyway, everything works great with the Contour electric fan set up, they rarely come on when I'm actually moving, usually just at stop lights and things. Even when its 100*F or more they don't run continuously.
    That's on a '68 340 with ported iron heads, 9.8:1 compression, bored .060" over, and making in the neighborhood of 420-430 hp.
    And, there are quite a few threads on this already. A few folks have had some quality control issues with the Champions, and pretty much everyone has to drill new mounting holes because the "factory" ones are in the wrong spot for these cars. But, for a radiator that you can often get for around $200 depending on the model, that's not too bad.
    [​IMG]
    [​IMG]
  15. 1968dartman
    1968dartman life is getting better!!
    2,991
    75
    Jul 28, 2011
    Moncton, NB
    Local Time:
    9:29 PM
    I have a 26 in champion in my Dart and I really like it!!
  16. dusterdoug
    995
    145
    Sep 26, 2007
    Tracy, CA
    Local Time:
    7:29 PM
    Great info guys! Thank you.
    While I usually agree with the "you get what you pay for" thought, it seems there are a quite a few happy Champion customers out there.
  17. Rodzilla
    Rodzilla Well-Known Member
    1,152
    59
    Jan 6, 2011
    Red Deer, Alberta
    Local Time:
    8:29 PM
    26" 4 core champion in my Demon. Running dual electric flex-o-lite pusher fans that have their own shrouds and at 605hp it stays cool in stop and go traffic up to 80F outside, at 90F in stop and go traffic it starts to get hot and can run at 200-210. Our weather mostly sucks at home in Canada, so it's almost never over 180deg in any kind of traffic.
  18. mopowers
    6,219
    3438
    Feb 15, 2006
    West Sacramento, CA
    Local Time:
    7:29 PM
    Thanks for the info 72bluNblu!! I'll probably be installing a Champion radiator soon as well. Summer is just around the corner.
    Wouldn't the thermostat remain closed if it was too cold? I'm not sure why the engine couldn't warm up since the water doesn't circulate with a closed thermostat.
  19. rnaz
    rnaz nitrous fed 390
    483
    23
    May 25, 2010
    Detroit
    Local Time:
    10:29 PM
    I, too, am running a Champion radiator in my Dart, and it's cooling an 11:1 390CID stroker that makes a bit less than 500HP at the crank. I regularly drive it on the street, and I frequently race the car.
    I'd recommend them to anyone.
