Cheap headers, and power steering?
Mopar Exhaust Systems
  1. NWDave
    NWDave Well-Known Member
    104
    1
    Jul 9, 2009
    Mukilteo, WA
    Local Time:
    8:28 AM
    So, I'm shopping around for a set of cheaper headers for my '71 Valiant, and was wondering if the power steering gets in the way?
  2. NWDave
    104
    1
    Jul 9, 2009
    Mukilteo, WA
    Local Time:
    8:28 AM
    And, the column shift linkage, anyone?
  3. jasonmrenda
    jasonmrenda Well-Known Member
    276
    0
    May 13, 2009
    Local Time:
    10:28 AM
    i cant say it's a universal thing but i know getting my headers off the 318 was a major pain in the neck. had to remove the starter, the power steering box and part of the steering linkage. i re-read the manual and the instructions from summit and evidently this is common practice.
    hope that helps somehwhat.
  4. Badart
    Badart Senior Member
    5,288
    89
    Feb 14, 2009
    Northern Utah
    Local Time:
    9:28 AM
    I can speak for the hooker comp headers. They do clear the power steering, big starter and shift linkage. They are a pain to install. Have a buddy hanging around because it takes about 4 hands and patience. They do hang low and capture the drag link on your steering, but are worth the headache. Hope this helps.
  5. NWDave
    104
    1
    Jul 9, 2009
    Mukilteo, WA
    Local Time:
    8:28 AM
    Sticking with the stock exhaust manifolds is sounding more and more appealing to me now!
  6. SpeedracerX
    SpeedracerX Still on this side of the dirt member
    3,521
    97
    Nov 19, 2008
    Irwin, Pa
    Local Time:
    11:28 AM
    thats what I thought after what it took to get my Hookers in the Dart... I had a slight clearance issue with the steering box, and had to remove the starter and take the drag link out first.... I love the headers.. but they were a pain in the ass! LOL
  7. '74 Sport
    '74 Sport Well-Known Member
    1,573
    45
    Oct 23, 2004
    Troy, TX
    Local Time:
    10:28 AM
    Dynamax headers fit in my son's '74 Duster with a little coaxing (no hammers used). Has a 360, mini starter, and power steering. The only major issue we had was a clearance problem with the steering shaft coupler. Had to do a little modification. Their price was right, too.
  8. Poppabear
    Poppabear Well-Known Member
    828
    0
    May 13, 2009
    Ozark, AL
    Local Time:
    10:28 AM
    jason how did yo get the bolts back in the steering box, I can't seem to get mine in
  9. 68 A
    68 A Well-Known Member
    563
    14
    Apr 16, 2006
    Auburn, NY
    Local Time:
    11:28 AM
    I put a set of Dougs on this year. I took a set off (they look like the hookers, but i'm not sure if they were) they had been hammered in to clear and the steering column would hit if you turned right. When I put the Doug's on they were hitting the drivers side torsion bar and the steering box. It ended up that my engine was not in the correct spot in the engine bay and I had to move it over to the passengers side an inch.
    You might want to look into that.
    Steve
  10. mod5v
    mod5v Well-Known Member
    647
    112
    Feb 17, 2006
    fortworth
    Local Time:
    10:28 AM
    Leave the header loose and hanging down. Reinstall the steering box and then bolt the header to the head. I had to do that with the manual steering box also.
  11. jasonmrenda
    276
    0
    May 13, 2009
    Local Time:
    10:28 AM
    sorry - just realized i had been asked a question and never responded.
    Poppa - all i can say is it took me a while, lots of sweat and some cursing but i did it.
    1 - loosen engine mount bolts and jack up engine as far as you can
    2 - make sure headers are lined up properly and then pull them off the studs and raise them as high as you can
    3 - i am short so i stood on a tire and just kept shimmying the pow steering box into place while maneuvering the headers out of the way until i got the box between the headers and the mount
    4 - from there i just turned/twisted etc until i could get the top bolt into the pow steering box to keep the box in place
    5 - then i went beneath car and did the other 2 bolts
    6 - make sure starter is in now too!
    7 - tightened everythin up, installed oil filter on left side, dropped the engine down, tightened eng mounts and header bolts and voila. lost about 10 pounds of sweat, ripped all my knuckles open and cursed like a sailor all the while, but it got done!!
    an extra set of hands is a HUGE help by the way!
  12. cavemanmoron
    cavemanmoron Well-Known Member
    1,797
    2
    Dec 12, 2005
    fn32
    Local Time:
    11:28 AM
    8)
    For street driving, its hard to beat the stock manifolds;
    especially if your engine makes less than 400 hp. ;)
    Here is my 1964 Valiant,
    318 with a mild buildup; Dual Exhaust off the stock 1964, 273 manifolds.
    http://www.youtube.com/watch?v=Ud8mci4rjFU
  13. 72dart_swinger
    72dart_swinger Well-Known Member
    451
    9
    Oct 2, 2009
    Local Time:
    11:28 AM
    I put a set of Hooker hedders on a 72 dart with a 360 and they were a pain. I also had some clearance issues with the idler arm on the passenger side. My car also had power steering and we had do put a small dent in one tube for the power steering unit. They were a pain to put on but they do sound good.
  14. 70DartMike
    70DartMike Too many projects
    7,610
    320
    Jul 17, 2007
    Vancouver Island, Canada
    Local Time:
    8:28 AM
    70 Dart with 318 with Hooker Comp headers. Didn't have any issues with the steering box itself, just with the steering shaft coupler, and the idler arm rubbing.
  15. juergen
    juergen Well-Known Member
    202
    1
    Sep 21, 2008
    Local Time:
    10:28 AM
    I used the cheap summit´s own brand headers in my ´69 dart 340, power steering, ministarter. Passenger side was an easy fit, drivers side made some trouble on the steering box, pitman arm and the coupler. I´m sure they are an easy fit with manual box.
    Greetings
    Juergen
  16. nqkjw
    nqkjw Well-Known Member
    505
    13
    Jul 8, 2006
    Nth Queensland,Australia
    Local Time:
    1:28 AM
    That would be these I guess?
    http://www.summitracing.com/parts/SUM-G9040/
    I've recently got a 72 Dart Swinger with 318/904 PS & AC and I was thinking of these as a cheapy.
    http://www.summitracing.com/parts/PTE-H8206/
    Anyone tried them?
  17. Dakota_Don
    Dakota_Don Well-Known Member
    208
    1
    Mar 19, 2008
    Local Time:
    10:28 AM
    have you looked at headman at summit..if i remember the chart says it will fit with p/s air, auto w colum shift..
  18. Dakota_Don
    208
    1
    Mar 19, 2008
    Local Time:
    10:28 AM
    maybe try dakota shorty headers..
  19. juergen
    202
    1
    Sep 21, 2008
    Local Time:
    10:28 AM
  20. abodyjoe
    abodyjoe Well-Known Member
    20,706
    5879
    May 22, 2004
    Berlin,N.J. 08009
    Local Time:
    11:28 AM
    i ran both headman and hooker compition headers on my dart with power steering and column shift. i think the headmans fit a little better in my car. they both hang low and are a pain to get to a few plugs but they are cheap and work. i have tti's now and will spend the extra in the future for tti's because the fit is so nice.
  21. mtandrews
    mtandrews beware the Ides of March FABO Gold Member
    17,446
    2805
    Jun 2, 2010
    Wilson County, Texas
    Local Time:
    10:28 AM
    do they fit?
  22. myasylum
    myasylum Well-Known Member
    1,784
    12
    Sep 18, 2008
    Las Vegas, NV
    Local Time:
    10:28 AM
    I have Headmans, they are a pain like all headers are, but no power steering issues and no banging.
  23. Dusted73
    Dusted73 Member
    16
    1
    Jun 13, 2020
    Vermont
    Local Time:
    11:28 AM
    Has anyone used the block hugger shorty headers on a power steering car with column linkage?
