Cheap tubular control arms for replacements?
Suspension, Steering and Chassis
  1. seabee
    seabee FABO Gold Member FABO Gold Member
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    I have spent two days pb-blasting, heat to red hot, and trying to press out one side of my upper control arm bushings. I even bought the special tool and resorted to a 6-ton press with no results. So instead of wasting any more time i am going to replace this neglected, rusted, pos and go with replacement part.
    Anyone recommend some less expensive ($<200) tubular replacements? Or should i go junk yard?
  2. crackedback
    crackedback FABO Gold Member FABO Gold Member
    18,212
    3572
    Aug 7, 2005
    92201
    Local Time:
    9:19 PM
    Before you do that, have you tried burning out the bushing, then cutting the sleeve, fold it in on itself.
  3. MileHighDart
    MileHighDart Well-Known Member
    4,450
    4292
    Jun 3, 2004
    Lakeview, OR
    Local Time:
    5:19 AM
    I dont think I've seen any of the aftermarket tubular control arms for less than $300.
    If they were cheaper maybe I'd have a set.
  4. MileHighDart
    4,450
    4292
    Jun 3, 2004
    Lakeview, OR
    Local Time:
    5:19 AM
    Can I ask what year/model are you working on ? And are you trying to go with the 73-up large ball joint setup ? Or the earlier small joint set up ?
    I may have some control arms that would help you.
    Scott
  5. seabee
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    Hi Cracked,
    It has another sleeve surrounding the bushing so kinda limited to what i can fold:[​IMG]
  6. seabee
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    Milehigh: 1966 barracuda. I have already bought the PST kit for the small ball joints.
  7. efriedrich
    efriedrich 69 383S
    1,260
    16
    Mar 21, 2010
    Indiana
    Local Time:
    12:19 AM
    I got some from pst a few months ago for 199.
  8. mullinax95
    mullinax95 Well-Known Member
    11,311
    402
    Oct 25, 2006
    Anderson, SC
    Local Time:
    12:19 AM
    Are pressing on the right areas to relieve the bushing? It looks pretty rusty however.
    Awhile back there was some pics of a Charger (I believe it was) that was wrecked. One of the tubular arms broke in which caused the crash. I don't know hate to start anything here but I like the stock arms better.
  9. RustyRatRod
    RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
    81,507
    61121
    Jun 7, 2010
    Georgia
    Local Time:
    12:19 AM
    Using "cheap" when describing suspension parts on a car is like using "cheap" when lookin for new airplane wings.
  10. grimreaper
    grimreaper Cross Member
    3,412
    905
    Jul 8, 2005
    Gillette, WY
    Local Time:
    10:19 PM
    When they're rusty like that and don't want to come out with my bushing puller I cut across them with the Sawzall right where that rubber is bulging. The inner sleeve and rubber can come out at that point. That's when you cut a slot along the inner length of the outer sleeve(careful, not so far you actually cut into the control arm) and pry one edge over the other as Crackedback recommends.
  11. RustyRatRod
    81,507
    61121
    Jun 7, 2010
    Georgia
    Local Time:
    12:19 AM
    Here:
  12. seabee
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    Thanks all very much for the input. I pushed the inner bushing out with a press then did the cut and fold method above. The thing was so fused to the arm i even had to grind off some remenants with a Dremel.
  13. seabee
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    But then i found a cheaper, lightweight solution to this age-old problem:
    [​IMG]
  14. MileHighDart
    4,450
    4292
    Jun 3, 2004
    Lakeview, OR
    Local Time:
    5:19 AM
    If your interested, I have a set from a 71 Scamp, New PST polygraphite bushing (installed) and new ball joints (installed). I put these on my car and drove it maybe a couple hundred miles before I parted that car out. They have just been sitting around since then. I could let you have them for $125 to your door. These are clean, rustfree colorado parts.
    Nevermind, looks like you figured it out.
  15. MileHighDart
    4,450
    4292
    Jun 3, 2004
    Lakeview, OR
    Local Time:
    5:19 AM
    At least that setup wont rust on ya.
  16. ocdart
    ocdart Inland Mopars Car Club FABO Gold Member
    9,198
    3481
    Nov 5, 2006
    North OC, SoCal
    Local Time:
    9:19 PM
    Yep, those are the cheap ones alright!
    Light too.
  17. Raleigh Rocket
    Raleigh Rocket Shake 'n' Bake!
    315
    2
    Oct 19, 2010
    North Carolina
    Local Time:
    12:19 AM
    This school of thought works pretty well for Uncle Sam. The only country in the world that can whip us in the air is Israel, and they're using our hand-me-downs.
  18. hellion_locdogg
    hellion_locdogg Slant Sickness
    625
    2
    Jun 22, 2010
    Phx,Az
    Local Time:
    10:19 PM
    I'll take two... lol
    p.s. I have UCA's from a '72 Dart if needed....
  19. seabee
    2,502
    681
    Dec 20, 2009
    Bonita, CA
    Local Time:
    9:19 PM
    Man, if I knew this a few weeks back before i bought the whole pst kit i would have been all over it. I'll be sure to pass this along to the next person I see before they go through this whole, (and more expensive) process.
  20. old mopars
    old mopars Well-Known Member
    530
    0
    Feb 7, 2010
    Connecticut
    Local Time:
    12:19 AM
    They might even "foil" a hillbilly radar detector
  21. RustyRatRod
    81,507
    61121
    Jun 7, 2010
    Georgia
    Local Time:
    12:19 AM
    Israel can whoop a lot of countries you wouldn't think otherwise. I'm waitin to see Iran piss um off good enuff. I wanna front row seat.
  22. RustyRatRod
    81,507
    61121
    Jun 7, 2010
    Georgia
    Local Time:
    12:19 AM
    That's some funny stuff right there.
  23. crackedback
    18,212
    3572
    Aug 7, 2005
    92201
    Local Time:
    9:19 PM
    Look at the replacements you have and this pic, it will tell you what you can and can't cut. Before you cut, measure the OD of your bushing and the OD of that sleeve to the inside of the A arm. They may be different from my pic and longer than the later model arms. You can cut the end off of the bushing on the outer sides, then you can burn/dig out the rubber.
  24. jrlegacy23
    jrlegacy23 68 Barracuda
    2,604
    308
    Jun 27, 2006
    Laurens, NY
    Local Time:
    12:19 AM
    Looks like you decided to go with CAP?
  25. Tony Fields
    Tony Fields That's How I Roll Legendary Member
    8,671
    364
    Aug 8, 2006
    Columbus, Indiana 47201
    Local Time:
    12:19 AM
    I hope you went with the super heavy duty foil and not the
    cheap stuff. It will corner much better if you did.:thumbup:
