Choosing a speedometer
Mopar Interiors
  1. Craig Burriss
    Craig Burriss Well-Known Member
    248
    161
    Aug 30, 2017
    Statesboro Georgia
    Local Time:
    2:54 AM
    So I took my 70 duster out for the first time in the 3.5 years I’ve owned it and everything went great except for when the speedometer made a loud snap noise and started bouncing all over the place. When I was doing around 55 it said I was doing 90 and when I was stopped it said I was doing 60. I removed the cable and took the cluster out but the needle never left the 20mph spot. I’ve been reading through here and see that it’s going to be expensive to repair the factory speedo. So my question is, if I get an aftermarket speedometer, how would I make it accurate for my gear ratio and tire size? I have a T56 magnum so I could go mechanical or electrical. Also what aftermarket speedometers do y’all have? I want something that goes higher than the factory 120mph.
    Thanks
  2. roccodart440
    roccodart440 Well-Known Member
    5,527
    4546
    Apr 19, 2010
    Local Time:
    2:54 AM
    Autometer GPS speedo. NO cables, no gears, easy peasy.
    • Like Like x 2
    • Veryfastdart
      Veryfastdart Well-Known Member
      559
      105
      Feb 28, 2010
      Hampton NH
      Local Time:
      2:54 AM
      roccodart440
      Where would you purchase this?
      Thanks
    • roccodart440
      5,527
      4546
      Apr 19, 2010
      Local Time:
      2:54 AM
      I bought mine direct from autometer.
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,611
      1041
      Apr 19, 2010
      San Jose, California
      Local Time:
      11:54 PM
      Repairing your original is cheaper than buying new.
    • my68barracuda
      my68barracuda Well-Known Member
      1,178
      866
      Dec 6, 2009
      Indianapolis IN
      Local Time:
      2:54 AM
      I have had Deluxe Speedometer / Denver rebuild two speedometers. Each was completed in a timely manner at a reasonable price. I recommend them.
      • Thanks! Thanks! x 1
      • 65 Dartman
        65 Dartman FABO Gold Member FABO Gold Member
        11,116
        2798
        Sep 24, 2006
        Strasburg, VA
        Local Time:
        2:54 AM
        Ditto on Deluxe Speedometer ^^^^^^. They have rebuilt several 65 Speedo’s for me that I ended up eventually selling.
        However, for my 65 wagon I decided to go with a custom dash using a 66 Barracuda bezel with a Dakota Digital conversion. The speedo is user programmable.
        For my 47 I am going with Speedhut gauges. I chose for my Speedometer the 120 MPH gauge although higher speeds are available.
