classic industries 68 cuda headlight bezels
moparmat2000
Grand Tetons
Hi Y'all,
I am looking at the classic industries 68 cuda headlight bezels. Mine are shot, and at $300 a side to refurb, i think the ones from classic industries are a deal at $450 for new if you can call $450 a deal lol. Anyways i know the 68s have an extra screw hole, but other than that, do they fit the same as on a 67? My 67 is not going to be 100 point show original anyways. I dont mind drilling an extra hole in the fender for an additional mounting screw.
Thanks in advance
Matt
Well I don't know the answer directly but, I have a 68 I'm building and if you send me a picture of it or count the holes I can check my bezels.
Hey Matt;
Just to letcha know, many of the 68 Cuda Guys prefer the 67 Headlight Bezel because they feel it is a cleaner look w/o the side bolt hole. They still bolt up the same.
I would stay away from drilling the hole. The OEM hole has been chamfered, which you will have a hard time duplicating with Aluminum.
______________________________________________________________________
If you have the opportunity to go with OEM parts for your Cuda, I highly recommend it. I think you will find sending a decent core pair to me for redo will far exceed the repros and at 220 each, it's worth the reassurance of knowing your OEM Stuf is gonna work PERFECTLY.
:D
I'm interested in the overall quality fit and finish of the classic industries re-pops...i'm looking at a set for my 68 Fastback
Hey Matt;
:D
As an aircraft sheetmetal structures mechanic fabricator, I have been able to duplicate the pressed in countersinks in aluminum and steel sheet . Its not actually a chamfer, rather its pressed as a countersink.
I have various steel blocks with countersinks in them. These are fit behind the hole you are wanting to press into a countersink. Then you fit a countersink machine screw into the hole from the front side, and thru the block with the countersink, and attach a nut the the end of the screw, and tighten down pulling the screw in pressing the metal into a countersink shape.
However the 68 bezels already have an additional hole in them, all i have to do is add a small drill hole to each fender for the additional screws. As long as they fit the same as a 67 thats the important thing, since they are listed as 68, and i would be putting them on a 67.
