"clicking" under the dash
Electrical and Ignition
  1. Pateras
    Pateras Well-Known Member
    233
    36
    Jan 2, 2014
    SW Colorado
    Local Time:
    11:58 PM
    Hi guys,
    I've done some brief searching and didn't come up with anything, so if this is covered somewhere i apologize.
    Here's the problem; I pulled out the dash a couple weeks back to deal with the smoked Amp meter. I bypassed the ampmeter all together, put everything back like it was (seemingly) but as soon as i turned the key on, I started noticing an audible clicking under the dash, about every 2 seconds, even when it's not running. I didn't think much of it, thinking i would deal with it later. well, i drove the car later and realized that that clicking was coinciding with the car momentarily dying while driving down the road!
    So, i can hear the click, see the lights dim on the dash, and the car dies every 2-3 seconds while driving 40 miles an hour. Crazy I know. Sound familiar at all? Thanks in advance.
    :banghead:
  2. memike
    memike Super Moderator Staff Member FABO Gold Member
    48,899
    8925
    Jan 8, 2006
    on the hill
    Local Time:
    12:58 AM
    Hmmmm I am puzzled :happy1:
    • Like Like x 1
    • momoparman
      momoparman MOISMYHOME
      3,147
      318
      May 31, 2008
      M I Z Z O U
      Local Time:
      12:58 AM
      Get a wiring diagram at mymopar.com then go back and visit what you did. If it worked before then it should work again. Sounds like you mixed up some wires or messed up some wires.
      If your harness got hot when the amp gauge melted down then you may have wires in the harness that have insulation melted and they are touching each other.
      Yes, I have had this happen on a 68 cuda, and when it did the wipers came on without the switch on, the radio power and the dash lights also. WITH THE KEY OFF! Also it would start but not stay running.
      I un-taped the wiring harness where it had gone through the ammeter and low and behold several wires and the black hot lead had fused together causing the circuits to be fed hot all the time.
      If you got hot and melty then look there first.
      Good luck.
      • Like Like x 1
      • Pateras
        233
        36
        Jan 2, 2014
        SW Colorado
        Local Time:
        11:58 PM
        The only thing i didn't put back was a crappy home made wire (couldn't have been a ground) from the inside dash metal to the inside plastic bezel. WTF people??
        Must have been the same person that cut a massive hole in the dash bezel with a chainsaw for a crappy 70's digital clock that i found laying inside the wiring. wasn't even hooked up. People are unreal. I'll post pictures of this psychosis soon.
      • Pateras
        233
        36
        Jan 2, 2014
        SW Colorado
        Local Time:
        11:58 PM
        Exactly, thank you sir. I just ahven't had a couple hours to throw at the problem. I have wires touching somewhere, just wondered if anyone had heard of this. Thank you!
      • pishta
        pishta I know I'm right....
        13,912
        3616
        Oct 13, 2004
        Tustin, CA
        Local Time:
        10:58 PM
        if its a regular click, sounds like maybe a thermal contactor, like a flasher pulling something to ground like the tach feed?
        • Like Like x 1
        • ir3333
          ir3333 Well-Known Member
          4,042
          707
          Jun 1, 2008
          ontario,canada
          Local Time:
          12:58 AM
          mechanical voltage regulator?
          • Like Like x 1
          • RedFish
            RedFish Well-Known Member
            22,847
            1846
            Sep 5, 2007
            Local Time:
            12:58 AM
            So what car and inst' panel ? One part that does get unfused 12 volts from ignition switch ( some models ) and does have a open/closed thermal conduction... instrument voltage limiter.
            • Like Like x 1
            • Triple J
              Triple J Well-Known Member
              59
              2
              Oct 24, 2012
              Surprise,AZ
              Local Time:
              10:58 PM
              In the mean time disconnect the battery while the car is parked in your garage, just in case
              • Like Like x 1
              • Pateras
                233
                36
                Jan 2, 2014
                SW Colorado
                Local Time:
                11:58 PM
                Sorry, 67 Cuda. Just installed elec VR, but the clicking was happening before i converted from Mech VR. I hadn't thought of the instrument voltage limiter, thanks. THe battery was disconnected immediately, last thing i want to walk into is my 3 year project in flames in my garage, ha!
                Thanks guys, all this helps.
              • RedFish
                22,847
                1846
                Sep 5, 2007
                Local Time:
                12:58 AM
                So did you completely amputate that mechanical limiter or only disable it ( bend the little thingy ) ?
                OOPS we may be talking about 2 different parts.
              • Pateras
                233
                36
                Jan 2, 2014
                SW Colorado
                Local Time:
                11:58 PM
                Well, i had to move to a electric voltage regulator since i now have a dual field alternator. Great guys here helped me out with that as well. so removed it entirely, and installed an electric VR. Thanks.
              • RedFish
                22,847
                1846
                Sep 5, 2007
                Local Time:
                12:58 AM
                I C The instrument voltage limiter is inside the fuel gauge. This area could have been the original root of the problems. One of 3 studs on that gauge gets 12 volts. One has or had a plastic cap to cover it so it couldn't short to the wire in defrost duct tubing or anything else. The noise suppression cap is attached and covering another of the 3.
              • mopar head
                mopar head Well-Known Member
                2,646
                360
                Oct 21, 2008
                Right here, can`t you see me?
                Local Time:
                12:58 AM
                Maybe the PO wired the ign. circut through a relay? and now is being fed wrong?
              • 67Dart273
                67Dart273 Well-Known Member
                39,031
                6716
                Oct 14, 2010
                Idaho
                Local Time:
                10:58 PM
                Someone may have added a thermal circuit breaker?
                Try unplugging the headlight switch which has one built in
                Some short? in the 4x flasher or turn signals? Remove both flashers
              • Pateras
                233
                36
                Jan 2, 2014
                SW Colorado
                Local Time:
                11:58 PM
                You guys ready for this?
                So I found some time saturday to tackle this issue. The clicking was still coming from underneath the dash, so before i yanked the entire dash out, i wanted to isolate where it came from. I crawled underneath and started poking around. I found that the sound was coming from the wiper switch! Weird to say the least. I then remembered that I finally hooked the wiper arm back up while the dash was out last time.
                Thinking the motor and arm were bound, and just needed aligned, i took the arm back off, well, the clicking sound immediately went away. even more weird, so i tried connecting it again, and saw sparks! WTF?! i grabbed my meter, and sure enough, the body of the wiper motor has 12v to ground. unreal. so when i connected the arm, it shorted to ground, causing some relay inside the wiper switch to open periodically.
                I've left it disconnected, and deal with it over the winter. just crazy.
              • momoparman
                3,147
                318
                May 31, 2008
                M I Z Z O U
                Local Time:
                12:58 AM
                l LOVES ME SOME WIRING ISSUES!
                NEVER A DULL MOMENT WHEN THERE IS ELECTRICITY INVOLVED. :D
              • pishta
                13,912
                3616
                Oct 13, 2004
                Tustin, CA
                Local Time:
                10:58 PM
                book it Dano! now we have another gremlin to keep aware of. Nice thing about boards the the internet in general is the huge searchability of it. This will save the next guy loads of beer drinking time.
              • 67Dart273
                39,031
                6716
                Oct 14, 2010
                Idaho
                Local Time:
                10:58 PM
                On some cars the wiper switch, just like the headlight switch, has an internal breaker.
              • HemiMark
                HemiMark Well-Known Member
                8,067
                450
                Jun 2, 2006
                Pittsburgh PA
                Local Time:
                1:58 AM
                I thought it was the speedo cable not being clipped in all the way.
              • RedFish
                22,847
                1846
                Sep 5, 2007
                Local Time:
                12:58 AM
                OK You'll probably find the short circuit in the park switch just inside the gearbox cover. The thermal safety inside the 67 wiper switch is a strip of bi-metal. It will eventually crack in half. Then either replace entire switch or take the switch apart and route the safety out of the switch and attach a cycling circuit breaker on it outside.
                Went through all of this with our very first 67 notch. Variable 3 speed wipers.
