Cloudy spot on window? ??
Mopar Body and Trim
  1. N1ce2k1llu
    N1ce2k1llu Well-Known Member
    52
    23
    Mar 19, 2018
    Florida
    Local Time:
    6:26 PM
    Does anyone know what this is and if it's fixable? Not looking for "fix it by replacing it" answers.
  2. yellow rose
    yellow rose Overnight Sensation
    28,501
    25174
    Jun 19, 2015
    Central Washington
    Local Time:
    4:26 PM
    What happened? It's almost like it got sand blasted or something. I've never seen that before.
  3. BigStrok3
    BigStrok3 Mopar!
    1,665
    191
    Nov 14, 2007
    St.louis area
    Local Time:
    6:26 PM
    Almost looks like primer overspray
  4. N1ce2k1llu
    52
    23
    Mar 19, 2018
    Florida
    Local Time:
    6:26 PM
    It was like that when I bought it. Doesn't clean off, like it's in the middle.
  5. yellow rose
    28,501
    25174
    Jun 19, 2015
    Central Washington
    Local Time:
    4:26 PM
    Oh yeah...could be. Seems that would clean up pretty easy though.
  6. Heywodja
    Heywodja The Heartbeat Stops Here FABO Gold Member
    920
    547
    Aug 16, 2014
    Texas
    Local Time:
    6:26 PM
    try a flat razor blade or some 0000 steel wool with some wd40
  7. Dana67Dart
    Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
    7,860
    5468
    Jul 16, 2017
    Northern Colorado
    Local Time:
    5:26 PM
    Is the side window glass 2 ply like a windshield?(look at the top edge)
    I had a 56 ford pickup that had that type of side glass and odd things can happen to the plastic in between.
    It is possible that the glass got acid etched by mistake some how.
  8. Dana67Dart
    7,860
    5468
    Jul 16, 2017
    Northern Colorado
    Local Time:
    5:26 PM
    just remembered.. there are glass polishing compounds out there. like what is used for plastic headlight lenses but specifically for glass.
  9. billccm
    billccm Well-Known Member
    194
    141
    May 13, 2018
    Tucson
    Local Time:
    5:26 PM
    0000 steel wool and rubbing alcohol might fix it.
  10. brian6pac
    brian6pac Well-Known Member
    5,668
    4027
    Nov 15, 2016
    N.E.Ohio
    Local Time:
    7:26 PM
    I had a windshield separate, fog in the middle but I don't think the side glass is 2 piece's
    • Agree Agree x 1
    • Red63440
      Red63440 Olddawg
      533
      527
      Dec 13, 2011
      Batavia, NY
      Local Time:
      7:26 PM
      Isn't all automobile glass "Safety Glass"?
    • Blucuda413
      Blucuda413 Well-Known Member
      153
      109
      May 20, 2012
      Alexandria, Louisiana
      Local Time:
      6:26 PM
      If it is between layers of glass a little heat may make it go away. Be very careful tho..
    • Red63440
      Red63440 Olddawg
      533
      527
      Dec 13, 2011
      Batavia, NY
      Local Time:
      7:26 PM
      The cloudiness could be caused by de-lamination, the OP stated it wouldn't clean off.
    • Dana67Dart
      7,860
      5468
      Jul 16, 2017
      Northern Colorado
      Local Time:
      5:26 PM
      Windshields are typically laminated glass. Side glass is typically tempered BUT back in the day (my 56 Ford PU for instance) the side glass was laminated as well. Don't know when all side glass changed to tempered.
      • Agree Agree x 1
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        79,449
        57884
        Jun 7, 2010
        Georgia
        Local Time:
        7:26 PM
        If it is on the surface, the razor blade idea is by far the best idea.
        • Agree Agree x 1
        • Treblig
          Treblig Well-Known Member
          7,405
          4996
          Oct 5, 2013
          South Texas
          Local Time:
          6:26 PM
          If you slide your hand across the area and feel any type of roughness then it on the surface and you can polish it out.
          Treblig
        • nm9stheham
          nm9stheham Well-Known Member
          12,089
          3979
          Dec 20, 2013
          Waynesboro, VA
          Local Time:
          7:26 PM
          The 70's A body side glass was tempered glass IIRC.... my brother had one shatter on him.
        • toolmanmike
          toolmanmike Moderator Staff Member FABO Gold Member
          62,388
          51594
          Jan 18, 2006
          Iowa
          Local Time:
          6:26 PM
          Stop by your local glass shop. May be they could tell you. You may have to replace it.
        • zkx14
          zkx14 Duster De-ruster FABO Gold Member
          29,064
          26828
          Dec 23, 2012
          South Central PA
          Local Time:
          7:26 PM
          looks like a ghost hand trying to drive your car. lol
          If it's any kind of overspray/ residue, lacquer thinner should take it off.
        • SpeedThrills
          SpeedThrills FABO Gold Member FABO Gold Member
          1,868
          591
          Jun 3, 2008
          Very South Jersey
          Local Time:
          7:26 PM
          There ya go. If it cant be felt with a blade, its inside. We need more info. Where you at!? Reply!
          Glass shop will probably say, "Replace it", lol.
          • Agree Agree x 1
          • Tooljunkie
            Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
            20,102
            22234
            Jul 22, 2017
            Manitoba
            Local Time:
            6:26 PM
            Should be tempered.
            So its a single layer of glass.
            The older trucks commonly had duallite as it could be made by a glass shop to replace a broken one.
            • Agree Agree x 1
            • Mopar-Mitch
              Mopar-Mitch Well-Known Member
              2,172
              2472
              Jul 29, 2018
              Kentucky
              Local Time:
              6:26 PM
              Jewelers rouge and a buffer, be careful not to over heat it buffing take your time. I've buffed out winsheild wiper scratches with it.
            • N1ce2k1llu
              52
              23
              Mar 19, 2018
              Florida
              Local Time:
              6:26 PM
              It's on the outside. Tried paint thinner and a razor both had no effect.
            • 73 dart custom
              73 dart custom Well-Known Member
              1,349
              1104
              Mar 11, 2018
              Darwin, Ohio
              Local Time:
              7:26 PM
              Try a "magic" eraser and elbow grease?
            • 73 dart custom
              1,349
              1104
              Mar 11, 2018
              Darwin, Ohio
              Local Time:
              7:26 PM
              If a magic eraser doesn't work you might try window cleaner and newspaper. It almost, but not quite, looks like the milkiness that was on my windshield when I bought my dart that had been parked for years. My windshield was mottled/patterned looking though.... where the condensation had been and dried then repeated the cycle for who knows how many years. I used regular window cleaner and newspaper to clean mine. There is something in the ink in newspaper that shines glass. Just don't use the colored or glossy pages of the newspaper.
              • Agree Agree x 1
