Cluster Restoration
Members Restorations
  1. Sig 440
    Sig 440 Member
    23
    20
    Jul 25, 2020
    Australia
    Local Time:
    5:56 PM
    I’m giving my instrument cluster resto a go myself
    Disassembled and paint removed back to bare plastic ready for painting I will keep posting my progress as I go
    • Like Like x 1
    • Arron tate
      Arron tate T B L
      423
      331
      Sep 12, 2018
      USA
      Local Time:
      2:56 AM
      Hello Sig 440,
      Thanks for sharing your resto endeavor with all the FABO comunity.
      Question, How did you remove all the paint ?
      I look forward to your updates as I will be starting my retro this winter..
      Thanks,
      Stay Safe.....
      Happy Mopar :)
      Arron.
      • Agree Agree x 1
      • Sig 440
        Sig 440 Member
        23
        20
        Jul 25, 2020
        Australia
        Local Time:
        5:56 PM
        Hi Arron
        I use caustic soda mixed with cold water
        Just get a plastic container big enough to submerge the bezel
        Mix the caustic soda at half the mix ratio on the container
        Let it soak for a good couple of hours or until all the paint is removed
        Then dip it in a tub of white vinegar to neutralize the caustic soda
        Then rinse with water
        Make sure you use rubber gloves as it burns the crap out of your skin
        It will not harm the plastic
        Cheers Rob
        • Thanks! Thanks! x 1
        • Lord Sparky
          Lord Sparky Well-Known Member
          339
          246
          Dec 2, 2019
          Carlsbad, California
          Local Time:
          11:56 PM
          Is there any chrome on the cluster?
        • Sig 440
          Sig 440 Member
          23
          20
          Jul 25, 2020
          Australia
          Local Time:
          5:56 PM
          Lord Sparky yes it removes the chrome
        • Lord Sparky
          339
          246
          Dec 2, 2019
          Local Time:
          11:56 PM
          Will you try to re-chrome?
        • Sig 440
          Sig 440 Member
          23
          20
          Jul 25, 2020
          Australia
          Local Time:
          5:56 PM
          Yeah mate I am not going to have it done as per the original process but will spray it and mask up and spray the black.
          I will see how it goes. Had a mate mdo his the same way and it turn out pretty good because you are spraying onto clean plastic
          • MonkeyMadness
            MonkeyMadness Well-Known Member
            1,001
            1137
            Jun 13, 2016
            Yorba Linda California
            Local Time:
            11:56 PM
            :popcorn: I'll be watching this may be my next project.
            Do you know how the caustic soda reacts to clear plastic or plastic lens!?! I want to do this to my gauge cluster as well as my Radio cover and it has a lens
          • Sig 440
            Sig 440 Member
            23
            20
            Jul 25, 2020
            Australia
            Local Time:
            5:56 PM
            You will have to remove all lenses
            • Lord Sparky
              339
              246
              Dec 2, 2019
              Local Time:
              11:56 PM
              The spray chrome sucks. Never hardens—can’t touch without dulling it. After messing with respraying for weeks, I finally bought a new chromed piece. If you can live with metallic, use that.
              • Agree Agree x 1
              • Garethw
                Garethw Mopar. Because rocket science is too easy.
                424
                342
                Mar 10, 2015
                Georgia
                Local Time:
                1:56 AM
                I’m looking forward to see how this comes out. Lots of pics please!
              • RedFish
                RedFish Well-Known Member
                24,517
                3046
                Sep 5, 2007
                Local Time:
                1:56 AM
                Easy Off oven cleaner will remove paint, chrome, everything, without harming the white ABS bezel.
                I used about 40 dollars worth of Wesley Bleach-White in a soak tank to strip several rally bezels. For 1 small standard bezel, 1 can of oven cleaner should do it.
              • pauly
                pauly MOPAR or no car! FABO Gold Member
                2,009
                718
                Nov 1, 2012
                Holton, Michigan
                Local Time:
                1:56 AM
                I used EZ OFF Oven Cleaner on mine - worked like a charm. The chrome can be tricky - I used Molotow silver paint pens for the silver. A little tricky but came out OK. Used the carbon fiber overlays from Detroit Muscle Technology and the white face gauge appliques from WhiteFaceGauges.com.
                • Thanks! Thanks! x 2
                • Like Like x 1
                • Sig 440
                  Sig 440 Member
                  23
                  20
                  Jul 25, 2020
                  Australia
                  Local Time:
                  5:56 PM
                  Lord sparky would love to have that luxury of a new one but in Australia you have to deal with what you got
                  I can have it redone over here but at a cost of 1000 so I will try and give it a go myself
                  • Agree Agree x 1
                  • Sig 440
                    Sig 440 Member
                    23
                    20
                    Jul 25, 2020
                    Australia
                    Local Time:
                    5:56 PM
                    Plastic prepped with wax and grease remover and sprayed with adhesive enhancer
                    Then the top coat of chrome.
                    Now let it harden for a few days mask up and the do the black
                    • Like Like x 3
                    • 89on35s
                      89on35s Inferno Red Duster FABO Gold Member
                      1,745
                      1719
                      May 11, 2006
                      Martensville Sask. Can.
                      Local Time:
                      12:56 AM
                      What did you use for chrome paint?
                      Cley
                    • Sig 440
                      Sig 440 Member
                      23
                      20
                      Jul 25, 2020
                      Australia
                      Local Time:
                      5:56 PM
                      • Like Like x 1
                      • Sig 440
                        Sig 440 Member
                        23
                        20
                        Jul 25, 2020
                        Australia
                        Local Time:
                        5:56 PM
                        Bezel bakes in the oven for 30mins at 80c chrome paint nice and hard
                        Masked up ready for the black coat
                        • Like Like x 1
                        • Sig 440
                          Sig 440 Member
                          23
                          20
                          Jul 25, 2020
                          Australia
                          Local Time:
                          5:56 PM
                          Needles repainted and instruments clean and checked all good
                        • Arron tate
                          Arron tate T B L
                          423
                          331
                          Sep 12, 2018
                          USA
                          Local Time:
                          2:56 AM
                          Hello Sig 440,
                          Looking Great....
                          keep the installments of your endeavor coming...
                          P/S Do you have a picture of the cluster before you dissembled it? Would be neat to see before and after pix..
                          Thanks,
                          Stay Safe....
                          Happy Mopar :)
                          Arron.
                        • Sig 440
                          Sig 440 Member
                          23
                          20
                          Jul 25, 2020
                          Australia
                          Local Time:
                          5:56 PM
                          Unfortunately I don’t have any previous photos but it was not in good shape most of the chrome and paint worn off needles were badly faded
                          Finally finished didn’t come up to bad
                          Chrome paint looks alright not perfect but I’m not restoring to concourse conditions she is a cruiser so I’m pretty happy with it
                          • Like Like x 3
                          • Sig 440
                            Sig 440 Member
                            23
                            20
                            Jul 25, 2020
                            Australia
                            Local Time:
                            5:56 PM
                            I was playing around with my uv torch It’s a pity you can’t get black Light wedge bulbs for the cluster
                            Looks pretty cool
                          • 69conv
                            69conv error 401 FABO Gold Member
                            3,449
                            4698
                            Jan 27, 2013
                            Motor City
                            Local Time:
                            1:56 AM
                            There are some cool led replacement bulbs available you might want to consider while you're in there and maybe a digital instrument voltage regulator. Nice job!
                            • Agree Agree x 1
                            • 69conv
                              3,449
                              4698
                              Jan 27, 2013
                              Motor City
                              Local Time:
                              1:56 AM
                              • Agree Agree x 1
                              • Mike69cuda
                                Mike69cuda 64 is the new 17 FABO Gold Member
                                1,828
                                1352
                                Jan 2, 2018
                                Overland Park Kansas
                                Local Time:
                                1:56 AM
                                I am very intrigued by your temperature curing of the chrome paint. Curing the chrome paint was my biggest problem. How did you come up with the temp and time?
