1. 5.7 hemi
    5.7 hemi FABO Gold Member FABO Gold Member
    2,045
    591
    Apr 18, 2009
    Local Time:
    1:46 PM
    Check Hayden’s website, they say it’s their shortest fan clutch. If memory serves its 2.67 or 2.7 in length.
    • Agree Agree x 1
    • 5.7 hemi
      2,045
      591
      Apr 18, 2009
      Local Time:
      1:46 PM
      Found the measurements, 2947-2.707 and 2765-2.67. I had them flipped. That’s all my fault. I do apologize for my incorrect posts.
      • Thanks! Thanks! x 1
      • inertia
        inertia Well-Known Member
        3,112
        445
        Feb 4, 2011
        Victoria B.C. Canada
        Local Time:
        11:46 AM
        Every year. . . Same probs, same results, different pix and names.
        • Agree Agree x 1
        • famous bob
          famous bob mopar misfit
          11,487
          2903
          Aug 14, 2011
          okla
          Local Time:
          1:46 PM
          those measurements are for the front of the pulley to the front of the clutch itself, not the abc measurements . And, moving the radiator 'back" would be putting it closer to the engine , where I went to school. Moving it forward would be the way I would go, "if" I wanted to cut up my orig. form S cradle .
        • famous bob
          11,487
          2903
          Aug 14, 2011
          okla
          Local Time:
          1:46 PM
          AINT WE GOT FUN?
        • Daves69
          Daves69 Well-Known Member
          4,023
          2065
          Feb 20, 2011
          WestOfChi
          Local Time:
          1:46 PM
          :popcorn::popcorn:........... and the verdict is? Pitcures please! upload_2018-5-4_8-44-52.png
        • dart4forte
          dart4forte FABO Gold Member FABO Gold Member
          4,157
          570
          May 28, 2004
          Mesa, AZ
          Local Time:
          6:46 PM
          • dart4forte
            4,157
            570
            May 28, 2004
            Mesa, AZ
            Local Time:
            6:46 PM
            • famous bob
              11,487
              2903
              Aug 14, 2011
              okla
              Local Time:
              1:46 PM
            • moparmat2000
              moparmat2000 FABO Gold Member FABO Gold Member
              11,523
              2188
              May 13, 2010
              Grand Tetons
              Local Time:
              1:46 PM
              Hayden #2765 for 1990 jaguar XJ6 is very short. More importantly though, what setup did the factory run on these back then?
            • Daves69
              4,023
              2065
              Feb 20, 2011
              WestOfChi
              Local Time:
              1:46 PM
              Possibly similar to post 28?
            • BillGrissom
              BillGrissom Well-Known Member
              7,212
              325
              May 10, 2009
              Sacramento
              Local Time:
              11:46 AM
              4 bolts, same as a Mopar. But, little room for a box wrench. M-B owners grind the end of a box wrench to barely fit over the head, since an open-ended wrench risks rounding off the head. In my M-B, I bought bolts at Ace w/ larger heads so I can use an open-ended wrench. Of course, a Mopar will be using different SAE bolts, so get ones w/ the largest heads possible (if a choice). Insure the M-B fan will clear everything on the engine. I tried the other way, test-fitting a Mopar fan-clutch to my M-B diesel. While it bolted up fine, the Mopar fan blades would hit the T-stat tube. I recall verifying w/ a vernier that the pilot hole is the same diameter. That must be fairly universal, except some fan clutches come w/ a reducer bushing which you must insert to use on our Mopars. I expect the same pump is used on GM or Ford which has larger pilot shaft on the w.p. BTW, the M-B fan in the photo appears to have aluminum blades. Better to pick a later one w/ nylon blades, as most M-B guys do. Also, some of the thermal clutches lose their silicone fill, especially if not stored vertical in storerooms.
            • rrvolare
              rrvolare 19Swinger69
              1,758
              99
              Jan 25, 2010
              Michigan
              Local Time:
              2:46 PM
              I cannot believe this conversation is still on going .. do this and don't look back ... install pusher and the flex fan i told you ????
            • dart4forte
              4,157
              570
              May 28, 2004
              Mesa, AZ
              Local Time:
              6:46 PM
              Given my car is a numbers matching stock resto the option you suggest wont work for my application.
              • Agree Agree x 2
              • dart4forte
                4,157
                570
                May 28, 2004
                Mesa, AZ
                Local Time:
                6:46 PM
                Ok, the temps have cooled enough (102) for me to work out in the shop. Installed the clutch fan. As you can see from the pictiures theres room between the clutch and the radiator with the hayden 2947. Took a measurement and have at least an 1 1/4 clearance from the front of the clutch and the rad. The fan itself is in the same location the fixed fan with spacer.
                I should note that if you look at the picture I didn't have the bolts cinched up when I took the pic.
                • Like Like x 1
                • rrvolare
                  1,758
                  99
                  Jan 25, 2010
                  Michigan
                  Local Time:
                  2:46 PM
                  As you can see the GRIFFIN radiator looks exactly like factory tank setup minus #'s on tank .. you can paint it black ... My Dart also is Number matching car .. BUT who cares , i kept everything and going for HP an TQ now ..
                  • Disagree Disagree x 1
                  • mopowers
                    mopowers Well-Known Member
                    3,836
                    1025
                    Feb 15, 2006
                    West Sacramento, CA
                    Local Time:
                    11:46 AM
                    But, but, but a clutch fan will never fit in a big block A-body. LOL
                    Nice job!
                    • Agree Agree x 1
                    • 5.7 hemi
                      2,045
                      591
                      Apr 18, 2009
                      Local Time:
                      1:46 PM
                      Holy f’n crap! How is that you have sooo much more room than everyone else? Is your radiator really thin? Is your engine moved back some?
                      • Agree Agree x 1
                      • famous bob
                        11,487
                        2903
                        Aug 14, 2011
                        okla
                        Local Time:
                        1:46 PM
                        this wasn`t enough for mine .
                        How about stating in these continuing conversations, 'THAT WE START OFF W/ PUMP BOLT TO RADIATOR CLEARANCE ," RIGHT OFF THE BAT.??
                      • dart4forte
                        4,157
                        570
                        May 28, 2004
                        Mesa, AZ
                        Local Time:
                        6:46 PM
                        Come again??
                      • dart4forte
                        4,157
                        570
                        May 28, 2004
                        Mesa, AZ
                        Local Time:
                        6:46 PM
                        You have a part number for that rad?
                      • moparmat2000
                        11,523
                        2188
                        May 13, 2010
                        Grand Tetons
                        Local Time:
                        1:46 PM
                        I would imagine theres going to be a lot of differences depending on stock copper/brass or thicker aluminum radiator. Elephant ears, stock BB mounts, MP spool mount K, homemade mounts, etc.
                        Not working with a big block myself, but i went with an engineered cooling products aluminum radiator, and a Hayden clutch fan for a 1990 Jag XJ6 with an 18" 6 blade flexalite fan only gave me 3/4" clearance to the back of the radiator. I am using a spool mount K with soft polyurethane bushings so fore and aft movement from acceleration and deceleration will be minimum.
                        I was going to go with an elect fan originally but wanted a puller so it couldent be seen behind the grille. The thinnest 18" single would have hit the water pump flange, and 2 smaller dual fans i was afraid wouldent have the CFM i needed.
                        Any way you go, a proper shroud to duct things is a must. I made mine out of fiberglass, and resin with a homemade wooden/masonite buck and an old cotton T shirt. Maybe this idea will help some of you out. Blades for mechanical fan should be about half out of the shroud, and have at minimum 1/2" clearance between them and the shroud.
                      • moparmat2000
                        11,523
                        2188
                        May 13, 2010
                        Grand Tetons
                        Local Time:
                        1:46 PM
                        More pix. First is the risers made from old 2×4 blocks to get the proper height. The 1x1s on the back stiffen the mould, and give something to stretch and staple the cotton fabric to. The 3rd pic is of the mould release plastic and tapes. 4th pic, I used 4 coats of fiberglass resin on the cotton fabric, allowing time to dry between coats, and light scuffing between coats. This gave it a nice sandable gel coat and allowed it to get stiff enough to pull from the mould, then i screwed it down to a plywood board on sawhorses and fiberglassed the inside.
                        The wooden bucks dimensions, and circular disc diameter, offset, and height the most important things in doing this. The mould has to be perfect in dimension, since you are making the part from it. If the mould is off in any direction or height, your part will be too.
                      • rrvolare
                        1,758
                        99
                        Jan 25, 2010
                        Michigan
                        Local Time:
                        2:46 PM
                        Call griffin ............700- 800 dollars i do recall
                      • dart4forte
                        4,157
                        570
                        May 28, 2004
                        Mesa, AZ
                        Local Time:
                        6:46 PM
                        Thanks
