1. Evan Dutch
    Evan Dutch Well-Known Member
    506
    83
    May 11, 2016
    monroe north carolina
    Local Time:
    11:21 AM
    Hey.
    Can someone tell me the dimensions of the bolts that fasten the clutch assembly to the flywheel? Thanks.
  2. yellow rose
    yellow rose Doctor of Thinkology.
    15,415
    12022
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    8:21 AM
    Kinda depends on the pressure plate.
    For sure the shoulder needs to go into the flywheel. If you have what they call the scalloped pressure plate it takes its own bolt. I used to know the part number off the top of my head, but no any more.
    I'll grab a bolt for the scalloped plate and take some pictures in a bit and post them. If you have the scalloped plate and don't use the correct bolt (or try studs and nuts) you will fracture the cover. Learned that the hard way.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • Evan Dutch
      506
      83
      May 11, 2016
      Local Time:
      11:21 AM
      If it helps. I’m using the 440 source billet 130 tooth flywheel that will work with 10.5” clutch. This is the clutch kit I’ll most likely be using.
    • yellow rose
      15,415
      12022
      Jun 19, 2015
      Local Time:
      8:21 AM
      Dam I forgot to take those pictures today.
      Shit. I'll do it first thing in the AM and I'll take a couple of shot of the pressure plate. That way you can see what I'm talking about.
      For that pressure plate I think a shouldered bolt will be fine. The bolts I use would also work, but I need to get the part number. I started using those bolts exclusively after I cracked to pressure plate covers.
      • Evan Dutch
        506
        83
        May 11, 2016
        Local Time:
        11:21 AM
        Not a problem. Thank you.
      • Daves69
        Daves69 Well-Known Member
        3,936
        1937
        Feb 20, 2011
        WestOfChi
        Local Time:
        10:21 AM
        From the MP P4529113 kit if it helps...…….
        • yellow rose
          15,415
          12022
          Jun 19, 2015
          Local Time:
          8:21 AM
          That lower bolt MIGHT work for a scalloped pressure plate but for damn sure not the top bolt.
          I'm going to post some pictures here in a minute.
          • yellow rose
            15,415
            12022
            Jun 19, 2015
            Local Time:
            8:21 AM
            This is my personal junk. From the top:
            The bolts designed for the scalloped pressure plate.
            The next picture shows why you need that bolt. The shoulder is about to go into the cover and that's what centers the cover. The bolt shoulder centers the cover.
            The next picture is a Borg & Beck/Long pressure plate that uses a scalloped pressure ring. This in a clutch done by Cale Aronson at Black Magic Clutches. Those are his fingers that he designed. And you can see I can also adjust for base pressure and counter weight.
            The next three are pictures of what a sintered iron disc looks like. Some of what is being called a sintered iron disc is NOT site red iron. It's some bronze metallic shit we called Velvet-Touch or some shit like that way back in the day. You can see that this is an unsprung hub and has no way to even have a marcel spring.
            This clutch is used in what was a 12.4X at 109.XX MPH street car. My wife can drive the car.
            So...after all this, that's the bolts I use in the pressure plate. I had to think about it. When I bought my new flywheel I asked McLeod to throw in some new pressure plate bolts and they did. For free. So I don't have a part number, but you need a bolt with a long shoulder on it because that shoulder goes through the cover and into the flywheel to line everything up.
            Hope this helps.
            • Daves69
              3,936
              1937
              Feb 20, 2011
              WestOfChi
              Local Time:
              10:21 AM
              FWIW, The "MP P4529113 kit" includes flywheel AND clutch cover bolts.
              • Evan Dutch
                506
                83
                May 11, 2016
                Local Time:
                11:21 AM
                I appreciate the time you guys took to help me out.
                I’ll have to work on finding the shouldered bolts.
                Thanks.
              • yellow rose
                15,415
                12022
                Jun 19, 2015
                Local Time:
                8:21 AM
                Is the above picture screwing with me? Are you saying that's the MP kit and the top bolt is a flywheel bolt? Damn. My glasses ain't to good.
                I will say I haven't used anything but Pro Series ARP flywheel bolts in I don't know how long.
              • Evan Dutch
                506
                83
                May 11, 2016
                Local Time:
                11:21 AM
                I’ll call McLeod tomorrow and see if they can send me some of those bolts.
              • Daves69
                3,936
                1937
                Feb 20, 2011
                WestOfChi
                Local Time:
                10:21 AM
                Yes sir!
                For reference a flywheel bolt from the kit next to a stock flex plate bolt...……..
