Clutch pedal ID
sammie
ny
This clutch pedal was in the trunk of a dart I bought.. can anyone Idenify them? The brake pedal shape seems strange.
The spring is going to be really hard to find if you don't have one and need one.
No one repops the BEEFY HD spring, they only repop the smaller standard spring
This appears to be standard duty pedals as I think I am seeing the pedals running on bushings and not bearings.
I think the bearing is shot. maybe even missing altogether?
'75-'76 A body, the brake pedal has the goofy twist in it.
I went on Brewers web page and they show the 75-76 with the twist in the pedal. But the twist is in the opposite way ! Mine twist out the one they have twist in
Does it have the hole for clutch switch? Maybe heavy duty for 72 and up
