Do you like a B&B clutch or diaphragm?Looking for your recommendations on a decent, yet inexpensive clutch for a daily driver... 1972 Demon...mild build 318..a833. Go!
Thanks,
John
Diaphragm.Do you like a B&B clutch or diaphragm?
Select by Category - Mopar A833 4-Speed Transmission & Component Specialists
I removed the OC spring...so probably diaphragm.If you have your factory Clutch Pedal Linkage and OC Spring, check Brewers and get a Borg&Beck Clutch
That's a huge discount..!I see Holley has a Hays 3 finger on "clearance"...........
[/URL]
