Clutch suddenly grabbing too quickly
ozmoparjoe
Melbourne Australia
Hello all, am needing some advice with something that happened to me today, i took off from standstill pretty hard, all good, went into second gear and the throttle got stuck so i shut it down straight away, and rolled into a side street. After i freed up the throttle, i went to jump in and take off, started it up, went to put it in gear and couldn't select any, that's when i noticed the pedal felt different, turned it off, waited a couple of minutes, tried again and was then able to select gears, but only with the clutch pedal hard on the floor, and clutch is now releasing as soon as i lift my foot off the pedal. Also it has always had clutch shudder, but now seems to be much worse.
I had a look underneath and can't really see anything out of the ordinary, apart from a few pressure plate fingers slightly out of line (towards front) with the rest of them.
I also noticed that pedal feels "weaker" when running.
Could this be just a master cylinder issue?
Any advice much appreciated thanks!
i think i may have found the problem lol
Holy Chit! Was all the friction material laying in the bottom of the inspection cover?
