Coil bracket mount location on LD340 intake
Electrical and Ignition
  1. Wvbuzzmaster
    Wvbuzzmaster Well-Known Member
    116
    52
    Dec 12, 2020
    West Virginia
    Local Time:
    9:03 AM
    So on the Edelbrock intakes the coil bracket mounting pads are at two different elevations by probably 1/2” or more by design. The Edelbrock Performer was the same way as my new LD340, and I am not sure how the coil bracket is supposed to mount with those pads at different elevations. On the old intake the answer the last guy had was bolt down one side and zip tie the coil into the bracket... so that is definitely not the answer. Can someone enlighten me on the correct answer, or maybe there is a correct bracket I am missing and need to get? Thanks.
  2. Professor Fate
    Professor Fate Push the button, Max...
    1,559
    2025
    Jan 13, 2020
    Wisconsin
    Local Time:
    8:03 AM
    Factory smallblock coil bracket:
    Big block coil bracket:
    You need a small block coil bracket, or put a 3/4 inch spacer under one leg of the big block bracket with a longer bolt.
    • Like Like x 3
    • Agree Agree x 3
    • Wvbuzzmaster
      116
      52
      Dec 12, 2020
      West Virginia
      Local Time:
      9:03 AM
      Awesome! Exactly the picture I needed to see, I just need a new bracket all together cause well... not worth straightening the big block bracket I have for the small block... the hunt is on now fir that bracket. Thank you
    • Professor Fate
      1,559
      2025
      Jan 13, 2020
      Wisconsin
      Local Time:
      8:03 AM
      Mopar Small Block Coil Bracket Strap (vansauto.com)
      Currently out of stock (like everything these days), but they're out there.
      • Like Like x 1
      • 4spdragtop
        4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
        31,226
        11748
        Aug 28, 2009
        Wasting time here
        Local Time:
        8:03 AM
        @RAT ROD AL or @SGBARRACUDA or @xLURKxDOGx will have one guaranteed.
        • Thanks! Thanks! x 2
        • Like Like x 1
        • Agree Agree x 1
        • SGBARRACUDA
          SGBARRACUDA ROY FABO Gold Member
          19,568
          8009
          Dec 7, 2006
          PLANT CITY FL. and PERRY GA.
          Local Time:
          9:03 AM
          I have a few, I look to see if they are BB or SB.
          • Like Like x 1
          • SGBARRACUDA
            19,568
            8009
            Dec 7, 2006
            Local Time:
            9:03 AM
            • Like Like x 1
            • 1969cuda
              1969cuda Well-Known Member
              928
              1047
              Sep 9, 2007
              California
              Local Time:
              6:03 AM
              Going in my A100
              • Like Like x 2
