I'm looking for a performance coil that will work with the factory electronic ignition and chrome modual. If I replace the coil, can I keep the original resistor? Any suggestion would be appreciated.
I've ran the ACcell yellow box coil on my old daily driver dart. It was old and used when I got it, and I ran it for another 10 years, on a couple different vehicles. Big and bulky, but never had a problem with it and it worked fine with the std electronic ignition. That's not to say if you go buy a new one, it's going to last more then a week. Quality of parts in general, especially electrical parts, is almost non existent now
Yes that box takes their recommended coil and ballast resistor. It is not supposed to be run for more than 1/2 hour at a time. I would t use it on a daily driver. Kim
