[WANTED] Column Shift Linkage 1974 Dart 904 Transmission
Cars and Mopar Parts Wanted
  1. Bl1zzard
    Bl1zzard Member
    10
    18
    Nov 3, 2007
    Local Time:
    12:22 PM
    Contact Seller
    Hi there,
    I'm looking for the bottom half of the linkage for a column shift to a 904 transmission for my 1974 Dart. I have the rod that hangs down from the steering column to the transmission and the lever on the transmission but all the stuff in the middle is missing. Damned if I can find a replacement anywhere.
    Thanks.
  2. Mtrhead
    Mtrhead Well-Known Member
    732
    146
    Sep 19, 2018
    S.C.
    Local Time:
    2:22 PM
    I got it on a 74 duster but has slant6 auto
  3. George Jets
    George Jets Well-Known Member
    103
    97
    Jan 18, 2019
    Farmington MN
    Local Time:
    2:22 PM
    Mopar A Body 1974-76 Steering Column Shift Linkage
    Dart Duster Valiant 904
    eBay item number: 123036437195
    This is the linkage that shifts the gears on 1974-1976 Mopar A-Body cars
    with Column Shift Automatic and 904 Transmission. Correct for Dart Scamp Valiant Duster etc..
    This kit is for small block or 6 cylinder with 904 transmission.
    Here is the shift linkage kit you need. Costs a few bucks, can use the parts and pictures to use as references when talking to others about what you need. Or go ahead and buy this one from ebay.
    Good Luck with your 74 Dart project.
    • Thanks! Thanks! x 1
    • barracudakid
      barracudakid FABO Gold Member FABO Gold Member
      4,532
      220
      Mar 12, 2009
      king nc
      Local Time:
      2:22 PM
      Got it
    • Bl1zzard
      Bl1zzard Member
      10
      18
      Nov 3, 2007
      Local Time:
      12:22 PM
      First pic is the rod attached to the tranny, second one is the rod hanging down from the firewall. You can also see the kickdown swivel here, gonna use a Lokar cable for that.
    • Oldmanmopar
      Oldmanmopar Going left turning right FABO Gold Member
      6,184
      1153
      Jan 8, 2009
      Danielsville Pa.
      Local Time:
      2:22 PM
      I have everything for a v-8 with 904.$60 shipped for everything from the arm on the column to the trans. with all hardware and bolts. Parts are clean and ready to install
      • Like Like x 1
