Combination Valve Install question
Brakes for your Classic Mopar
  1. C2ndLTpigeon
    C2ndLTpigeon Mopar or no Car! FABO Gold Member
    769
    519
    May 18, 2019
    Indio California
    Local Time:
    7:28 PM
    Going to install a new combination valve on my 73 Valiant today, is there any bleeding procedure needed before install? Or will this take care of itself when bleeding the brakes?
    Thanks
  2. Krooser
    Krooser Building Chinese Free Engines since 1959...
    3,357
    2935
    Jul 19, 2015
    Central Wisconsin
    Local Time:
    9:28 PM
    Good luck getting it to work... all those new valves are junk... sorry to say.
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • C2ndLTpigeon
      769
      519
      May 18, 2019
      Indio California
      Local Time:
      7:28 PM
      Not really helpful... where else is someone to go when they have to replace one? Working with what is available.
      • Like Like x 1
      • jdsduster
        jdsduster Well-Known Member
        1,222
        204
        Aug 5, 2011
        indiana
        Local Time:
        10:28 PM
        i think someone rebuilds them,cant think of the name though
      • Professor Fate
        Professor Fate Push the button, Max...
        2,446
        3302
        Jan 13, 2020
        Wisconsin
        Local Time:
        9:28 PM
        It will take care of itself when you bleed your system.
        That said, be prepared for leakage, a common problem with the repro valves.
        Search the brake forum for the subjects of "leaking proportioning valve" or "leaking combination valve", etc. and "annealing copper washers".
        Also, open it up and clean it out as best you can, common to have manufacturing debris inside of them that makes them hang up when in use.
        Best of luck!
        • Syleng1
          Syleng1 Karma is real and Life is short... FABO Gold Member
          2,369
          2043
          Jul 5, 2005
          North Franklin, CT
          Local Time:
          10:28 PM
          FYI- new ones as mentioned sometimes have issues. Debris’s, leakage, cross threaded fittings.
          If your bolts up - Great. Then try to bleed the brakes and keep an eye on it when you do each wheel. If it leaks, then it’s a bad one. If not it will self bleed as you push fluid thru the system. Good luck!
        • Oldmanmopar
          Oldmanmopar Going left turning right FABO Gold Member
          9,433
          6274
          Jan 8, 2009
          Danielsville Pa. 18038
          Local Time:
          10:28 PM
          It will bleed itself. Those valves are good. It is the same valve I use with large bolt pattern single piston Kelsey Hayes calipers. That is the newer weather head style 73 and newer. The early for 66-72 was the kelsey hayes style it is the one on the right. I have not had problems with the aftermarket weatherhead style
          • Agree Agree x 1
          • 1969383S
            1969383S FABO Gold Member FABO Gold Member
            6,700
            3686
            Jan 8, 2012
            Cumming, GA.
            Local Time:
            10:28 PM
            Sometimes you just have to loosen and tighten all the fittings a few times to get a good seal!
            Especially if changing lines at the same time!
            • Agree Agree x 1
            • dartfreak75
              dartfreak75 Restore it, Dont part it! FABO Gold Member
              10,826
              8439
              Aug 10, 2011
              Virginia
              Local Time:
              10:28 PM
              Make sure to double flare your lines if your flaring them yourself. I think all the prebent stuff comes double flared
              • Like Like x 1
              • C2ndLTpigeon
                769
                519
                May 18, 2019
                Indio California
                Local Time:
                7:28 PM
                Took the new valve apart and cleaned it, I also took the old one apart to see if it was gunned up. Here are some pics of the new and old. The old one looks gutted. Does not have all the stuff the new one does, the old one also has initials and a reman date so it was rebuilt. Correctlly I don't know.
                New
                Old
              • 70dart340
                70dart340 FABO Gold Member FABO Gold Member
                1,195
                709
                Aug 10, 2007
                Puget Sound
                Local Time:
                7:28 PM
                I just bought a set from Rick Ehrenburg's Ebay store. They work perfectly, and are affordable. If you don't know Mr. Eherenburg, google him. A great Mopar resource. I'm not plugging him, I don't work for him, but his parts have helped solve a bunch of problems I've had on my '70 Swinger 340 brakes. If I've broken any rules, Mods, I apologize.
                • Like Like x 1
                • RustyRatRod
                  RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                  79,158
                  57451
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  10:28 PM
                  The old one appears to be a distribution block only.
                  • Agree Agree x 1
                  • Oldmanmopar
                    9,433
                    6274
                    Jan 8, 2009
                    Local Time:
                    10:28 PM
                    • Oldmanmopar
                      9,433
                      6274
                      Jan 8, 2009
                      Local Time:
                      10:28 PM
                      • Like Like x 1
                      • C2ndLTpigeon
                        769
                        519
                        May 18, 2019
                        Indio California
                        Local Time:
                        7:28 PM
                        Which may be the problem? Factory manual shows it would be a combination valve for disc brakes.
                      • RustyRatRod
                        79,158
                        57451
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        10:28 PM
                        Well it certainly appears to not be a proportioning valve, doesn't it? Is the car a factory disc brake car?
                      • C2ndLTpigeon
                        769
                        519
                        May 18, 2019
                        Indio California
                        Local Time:
                        7:28 PM
                        Factory disc, the valve was horribly rusty, installed the new combination valve, had to tighten the fittings good but so far no leaks, and fluid is staying where it should in the master!
                        I looked at the date on that original valve and it was put on there a month before I bought the car, prev owner wasn't very knowledgeable on stuff like that so they probably through the incorrect part on there.
                        • Like Like x 1
