67Dart273
Yes, friends, Del's at it again
Filled the bed of the new Sierra right up LOL
From top left, hidden by shroud is an old air cooled Eska ? 7.5, this is basically a Clinton 2 stroke lawn mower engine made into an outboard. The were sold under lots of names, including Ted Williams, Sears, etc. Had the Eska fired, but lower unit is trashed and has been freeze broke and welded. Likely parts I had an Eska given to me, no spark, so the other two will fix one, or maybe one will fix two??
Then the Johnson fuel tank, and to the right of that is a 59 Johnson 10. Had it running but not good, needs a tune up. It is in decent shape and complete, the "top" of the bunch
Down to the right is a Sears/ Eska it is stuck, and below that was a free Evinrude, no power head. More parts
Bottom left is dark blue Evinrude ? 7.5? unknown problems, has compression and no spark
Last is the Bucanner made by Gale/ OMC it is stuck. It is complete and in decent shape, and has a built-in fuel tank. I may "merge" with another motor I have to make a decent outboard.
Paid 20 for the nice little 2 1/2 gal plastic tank which I wanted. I have a 50-6 gal plastic tank, and don't think I'll need that much often or at all
