Solid roller lifters. Does the push rod seat come out so ur able to clean it or is there a problem. Thanks. Kim
If it has a snap ring or wire lock ring it should come apart. I f not it's one piece. Depends on who made it.Solid roller lifters. Does the push rod seat come out so ur able to clean it or is there a problem. Thanks. Kim
So, it is a 50/50 chance then?If it has a snap ring or wire lock ring it should come apart. I f not it's one piece. Depends on who made it.
didn`t the better lifters go to snap ring for just that problem ??Adjuster backed off and threw off the pushrod on number 2 cylinder exhaust. Cup was laying in the valley
