Comp valve springs
440 Mike
Minnesota
Apparently Comp no longer makes their 924-16 valve springs. They were spring rate of 347 with 112 lbs at 1.90" / 303 lbs. at 1.35". OD outer 1.509/ ID inner .697
Can anyone recommend a similar replacement spring?
If you want something closer to the original-
Howards 98636, 130@1.875/330@1.300
At the same checking heights- 121.3/312.6
That looks like a winner, thanks. I had considered going with the Comp 925's too, but I want something that I can break the cam in with using both inner and outer springs.
