Compression test results and plug color question.
Small Block Mopar Engine
  1. MileHighDart
    MileHighDart Well-Known Member
    3,777
    2786
    Jun 3, 2004
    Lyons, CO
    Local Time:
    6:31 AM
    So the other day I decided to run a compression test on my 5.9 magnum. Haven't done one since I put the engine together a couple years ago, so just decided to check it out.
    Numbers look pretty even across the board, all between 139 and 144.
    Plugs look kinda of black and sooty probably because the choke was on most of the time when I was warming it up before the test. (im guessing). But I know it's probably running a bit rich too.
    So most of the plugs are black or brown, but wondering whats up with #8 ?
    Looks bright white compared to the others. Any Idea why that one looks so lean?
  2. yellow rose
    yellow rose Doctor of Thinkology.
    19,474
    15609
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    10:31 PM
    What plug is that? You definitely have some distribution issues but number 8 looks the best at cruise. The rest of it would be a guess with the shells on the plugs but if it's that pig rich at idle and cruise it's probably pretty rich at WOT.
    What carb and intake? Cam timing?
  3. jimjimjimmy
    jimjimjimmy lobsterman FABO Gold Member
    4,336
    1113
    Nov 2, 2010
    p. e. i.
    Local Time:
    2:31 AM
    [QUOTE="yellow rose, post: 1972736343, member: 4180
    What carb and intake? Cam timing?[/QUOTE]
  4. MileHighDart
    3,777
    2786
    Jun 3, 2004
    Lyons, CO
    Local Time:
    6:31 AM
    Edelbrock Magnum airgap. Edelbrock 1406 carb. It's got a 5.2 Magnum cam. Don't remember all the specs right off, but I know it's 112 lsa and 110 installed center line.
  5. MileHighDart
    3,777
    2786
    Jun 3, 2004
    Lyons, CO
    Local Time:
    6:31 AM
    P S. I am getting ready to finally install my Innovate air/fuel gauge so I can dial in the carb a little better.
  6. yellow rose
    19,474
    15609
    Jun 19, 2015
    Local Time:
    10:31 PM
    Don't use the gauge until you learn to read plugs first. The gauge can send you down a rabbit hole.
    • Thanks! Thanks! x 1
    • GEO
      GEO Sarcasm Inc.
      1,924
      222
      Feb 12, 2012
      Irvington ,Indiana
      Local Time:
      12:31 AM
      number eight does looks odd, kinda like a head gasket issue where it is sucking coolant in the combustion chamber
      • Agree Agree x 1
      • oldkimmer
        oldkimmer FABO Gold Member FABO Gold Member
        13,224
        2966
        Nov 11, 2006
        Kindersley, Saskatchewan,
        Local Time:
        12:31 AM
        Or a vacuum leak on number 8. Kim
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        14,903
        3194
        Jan 16, 2005
        las vegas
        Local Time:
        10:31 PM
        at 5307 feet above sea level...i would be changing some metering rods...or jets around.
        • Agree Agree x 2
        • Like Like x 1
        • RustyRatRod
          RustyRatRod Weenie idiot loser. FABO Gold Member
          57,377
          26853
          Jun 7, 2010
          Georgia
          Local Time:
          1:31 AM
          What's that plug read from? Did you just take um out after driving around or did you do a wide open blast like you're supposed to and cut it immediately off? Exactly WHAT are we reading here? If it's idling in the driveway, They look pretty dang good.
          • Thanks! Thanks! x 2
          • Like Like x 1
          • MileHighDart
            3,777
            2786
            Jun 3, 2004
            Lyons, CO
            Local Time:
            6:31 AM
            Yes, it was just idling in the garage till warmed up. Didn't know about doing a wide open blast before pulling the plugs. And I didn't really pull them to read the plugs, but to do the compression test. Just thought I'd ask what you guys though cause #8 looked so much more white than the rest.
          • RustyRatRod
            57,377
            26853
            Jun 7, 2010
            Georgia
            Local Time:
            1:31 AM
            Yeah. You caint read plugs like that. You're supposed to get it up to temp, do a full throttle blast through the gears and "I" always shut r down before I even come to a stop good so the engine doesn't get into idle at ALL. Then look at um. Opinions vary, but that's MY method.
            • Thanks! Thanks! x 3
            • Agree Agree x 1
            • greymouser7
              greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
              3,142
              2469
              Apr 17, 2010
              78002 down the road from Atascosa, Texas
              Local Time:
              12:31 AM
              thankyou
              • famous bob
                famous bob mopar misfit FABO Gold Member
                14,701
                5056
                Aug 14, 2011
                okla
                Local Time:
                12:31 AM
                There was a pretty well known racer around Tulsa quite a few yrs. back , had a new 426 stage 3 wedge, 63 plymouth. He was going to do a plug read/chop the throttle , throwing it in neutral/shutting it down at the same time , to acuratly read the plugs. He went thru neutral into reverse , he ended up with jaws wired closed , and sold the drivetrain to another friend, that's all that was left !. He quit dragracing .
              • midnight340
                midnight340 Well-Known Member
                313
                170
                Mar 19, 2014
                Lawrence, KS
                Local Time:
                12:31 AM
                Having a reverse lock-out (like on the B&M Pro Stick) takes some getting used to, but I like it to avoid the risk of this sort of thing.
                ALSO if you have a locking column be careful shutting down, you need to be able to go where you planned!!
              • RustyRatRod
                57,377
                26853
                Jun 7, 2010
                Georgia
                Local Time:
                1:31 AM
                Those car were NOT play toys, even in "stock" form. If you can call it stock.
              • RustyRatRod
                57,377
                26853
                Jun 7, 2010
                Georgia
                Local Time:
                1:31 AM
                Exactly why they are NHRA mandated. I've always like them too, but they are a trick to get around quick sometimes.
                • Agree Agree x 1
                • midnight340
                  313
                  170
                  Mar 19, 2014
                  Lawrence, KS
                  Local Time:
                  12:31 AM
                  My local Mopar machine shop (that has built and raced Mopar engines for many years) has mentioned to me that it's not too unusual to have some fuel distribution variance, in particular, to be leaner on #8. Something about it being an end cylinder in combination with the way the firing order is designed.
                  And maybe this would be worse at idle as well???
                  (this according to my memory of a conversation months ago, so... you know.) :)
                • yellow rose
                  19,474
                  15609
                  Jun 19, 2015
                  Local Time:
                  10:31 PM
                  There are 4 cylinders with an extra corner in them, even with a single plane intake.
                  I'm thinking (not ready to test yet) that some of those distribution issues are really reversion related. I can't prove that, but that's what I think.
                  • Agree Agree x 1
                  • TrailBeast
                    TrailBeast Slightly Twisted Member
                    20,430
                    7345
                    Mar 11, 2011
                    Arizona
                    Local Time:
                    11:31 PM
                    Do you have a PCV, and where is it connected?
                    Might be the answer this time, but Rob is spot on about plug reading.
                  • MOPAROFFICIAL
                    MOPAROFFICIAL Well-Known Member
                    4,563
                    3549
                    Jun 1, 2016
                    Between a tit and an armpit
                    Local Time:
                    10:31 PM
                    Be careful if you have power brakes before shutting it down.
                    Check port alignment to head.
                    Disconnect the pcv, plug it and drive it cruising, no wot and then check the plugs again...who knows.
                    Everyone else have covered most things to check. Shortest wire of a set of crappy high resistance plug wires perhaps, lol. Maybe not, maybe you have good wires...maybe you fouled the plugs at one time, short of that one and they never cleaned up. Lol
                  • famous bob
                    14,701
                    5056
                    Aug 14, 2011
                    okla
                    Local Time:
                    12:31 AM
                    Not many reverse lock outs around in 1963--------
                    • Like Like x 1
                    • famous bob
                      14,701
                      5056
                      Aug 14, 2011
                      okla
                      Local Time:
                      12:31 AM
                      Agree with this post, we flowed 3 diff. intakes and there was a bunch of diff. in them , read hughs intake tests.
                      I got the victor down to 15 cfm scatter, and a toquer 2 down to 25, a weiand team g down to 24 , and I aint no pro -----
                      Would love to have Wilson manifolds do one for me , but $1500 is a too much for me !
                    • midnight340
                      313
                      170
                      Mar 19, 2014
                      Lawrence, KS
                      Local Time:
                      12:31 AM
                      True dat!! Unless you count the Hurst Mystery Shifter that I couldn’t get into reverse!!!!! :rofl:
