burdar
Owen's Dad
I built some clocks out of a used set of Carrillo H-beam rods. Each rod was cleaned, chemically darkened, heated and treated to protect from rust. The rods are not painted. The clocks stand up by themselves due to a roller lifter installed into the wrist pin end. Both Arabic and Roman numeral clocks are available. Clock inserts are 2 1/8" in diameter and are made of metal, not plastic. Clocks have a glass cover. Battery already install. Comes with an extra battery. $36 plus shipping. Clock will be shipped from Urbana, Iowa. May also be picked up if you live in the area. Thanks
