Console clean up
Mopar Interiors
  1. Holy Roller
    Holy Roller Well-Known Member
    671
    185
    Nov 22, 2014
    Nederland Texas
    Local Time:
    7:48 PM
    Is there any specific paint to repaint the console with. Also, what do you use to sand it down since the surface isn't smooth? Thank you, Your help and experience is appreciated.
    Joe
  2. dano
    dano Evil Handy Man FABO Gold Member
    2,380
    407
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    5:48 PM
    In for the same questions. Mine has some deep scratches. I've considered sanding it smooth and possibly using a textured paint.
  3. Mopar44134
    Mopar44134 Well-Known Member
    197
    2
    Jul 20, 2011
    Ohio
    Local Time:
    8:48 PM
  4. Holy Roller
    671
    185
    Nov 22, 2014
    Nederland Texas
    Local Time:
    7:48 PM
    I thought about using a mild paint remover and some prepall to clean it. But I'm not sure if there's a mopar paint that was used to paint it. Or if it's a aftermarket paint.
  5. Holy Roller
    671
    185
    Nov 22, 2014
    Nederland Texas
    Local Time:
    7:48 PM
    I had thought the same thing , like you said..it's a textured surface and a plastic paint might work.
    • Agree Agree x 1
    • Fgill
      Fgill Well-Known Member
      172
      186
      Feb 16, 2015
      washington
      Local Time:
      7:48 PM
      ...just a shot in the dark, but perhaps some sort of media blasting, very light psi and the right media may do it. idk.
    • Holy Roller
      671
      185
      Nov 22, 2014
      Nederland Texas
      Local Time:
      7:48 PM
      That could be a possibility, but might be a little costly something goes wrong and you mess up your console.
    • dano
      2,380
      407
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      5:48 PM
      The console is fiberglass and quite rugged accept in a few areas. I've cut and filled on mine because I have a larger tunnel for a TKO so I had to shave the nose to get it back to the stock location and be parallel to the floor. Mine has some deep scratches and broken corners, probably from being stored poorly by previous owners. I'll epoxy the broken parts. Light abrasive blast might work to keep the texture and strip a layer of finish. I have a small blaster/compressor and some walnut shells, might give it a try.
    • Holy Roller
      671
      185
      Nov 22, 2014
      Nederland Texas
      Local Time:
      7:48 PM
      I didn't know it was fiberglass, I thought it was like a pot metal or something light. That info was helpful. Thank you. Does anyone use a certain paint to repaint with?
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      38,675
      20975
      Jan 18, 2006
      Iowa
      Local Time:
      7:48 PM
      You talking about the console body or the top plates?
    • MobileCustoms
      MobileCustoms Well-Known Member
      1,548
      1078
      Oct 21, 2013
      Inver Grove Heights, MN
      Local Time:
      7:48 PM
      I would suggest filling any deep scratches or imperfections, and then spray it with this truck bed coating to get a reasonably good looking texture and finish, for the least amount of money. Just don't get it so wet that it runs! Take your time between light coats to obtain the desired texture.
      You can get this stuff most anywhere (Walmart, Ace, Home Depot, etc.)
      • Like Like x 1
      • dano
        2,380
        407
        Aug 22, 2005
        Gresham, Oregon
        Local Time:
        5:48 PM
        I'm talking about the base.
        The top plates if they are majorly pitted will be a pain in the ass to repair. My dad had that issue on a 1 year only 1966 Coronet 500 trunk trim panel, we ended up just buying a damn near perfect one for $1k. He had 2 of the trim panels and both were pretty pocked. He tried to them stripped, copper coat and fill but the pot metal just warped. With re-pops of the consoles covers I'd just get new ones, which is what I did but I have a manual and the console I bought was an Auto.
      • MobileCustoms
        1,548
        1078
        Oct 21, 2013
        Local Time:
        7:48 PM
        Are you referring to my post above? I was also talking about the base, the lower black.
      • Holy Roller
        671
        185
        Nov 22, 2014
        Nederland Texas
        Local Time:
        7:48 PM
        Console body
        • Like Like x 1
        • 4spdragtop
          4spdragtop FABO Gold Member FABO Gold Member
          25,717
          5167
          Aug 28, 2009
          Ontario
          Local Time:
          7:48 PM
          I used black shoe polish. Sit in sun. I didnt fix any Nick's though.
        • Holy Roller
          671
          185
          Nov 22, 2014
          Nederland Texas
          Local Time:
          7:48 PM
          The shoe polish didn't rub off on anything?
        • 4spdragtop
          25,717
          5167
          Aug 28, 2009
          Ontario
          Local Time:
          7:48 PM
          Nope, I didnt use lots, also the liquid stuff not the paste. Works like a dye I guess. Buddy of mine told me about it.
        • Holy Roller
          671
          185
          Nov 22, 2014
          Nederland Texas
          Local Time:
          7:48 PM
          Cool, I would've never thought of that..theres another option to consider. Thank you
          • Thanks! Thanks! x 1
          • tkoboat
            tkoboat Member
            23
            0
            May 16, 2008
            Local Time:
            7:48 PM
            SEM has a special textured paint for that.
            T
          • Holy Roller
            671
            185
            Nov 22, 2014
            Nederland Texas
            Local Time:
            7:48 PM
            Do you have a website for them?
          • RedFish
            RedFish Well-Known Member
            23,295
            2166
            Sep 5, 2007
            Local Time:
            7:48 PM
            I'll have to start at the beginning... my 67 buckets have steel backs with vinyl skin glued on them. Wrong kind of glossy spray paint with runs, Pretty bad scars and small dents to hammer out too. Lacquer thinner and a lot of rubbing removed the paint mess. In some spots I had to razor away loose vinyl. I filled the voids with gel type super glue. After it had a few minutes to cure a bit I pounced it with a piece of fine scotch brite pad and allowed it to cure fully. Very light sanding knocked down peeks and edges. Vinyl thickness with grain recreated. Shot with Sems Landau Black and done.
            My console wasn't scared so bad but had a rear corner broken out/missing. Built a form or fence with duct tape. built the missing corner with Devon 2 part epoxy. Pulled the tape and sanded to shape. Same pounce in super glue recreated the grain on that too.
            The correct very low gloss / nearly flat dye finish doesn't amplify imperfection like glossy will. I wont claim invisible repairs at every spot but one would need to look closely to find them all.
            • Like Like x 1
            • Holy Roller
              671
              185
              Nov 22, 2014
              Nederland Texas
              Local Time:
              7:48 PM
              Thank you Redfish, where do I find the Sems Landau black paint at?
            • RedFish
              23,295
              2166
              Sep 5, 2007
              Local Time:
              7:48 PM
            • Holy Roller
              671
              185
              Nov 22, 2014
              Nederland Texas
              Local Time:
              7:48 PM
