Cope
Fusing with fire
I'm looking for a u joint to go from my stock 71 318 drive shaft to my ford 9" yoke. Anyone got the part number?
I also need the the little tabs that the soft brake line goes into. You know the ones with the D shaped hole. Can I order them or anyone got some, I need 2.
I also need a new soft line to go from the rear hard line to my new rear axle. It must be long enough for use with SS springs. What do you use?
Where the new soft line goes into the T block on the axle, how is the block attached? Will it bolt on? The T block is not centered on the axle correct?
Thanks for all the help and advice.
