convert later 904 to typewriter
Transmission and Drivetrain Tech
  1. Thumpower
    Thumpower Well-Known Member
    133
    1
    May 4, 2011
    Ventura
    Local Time:
    1:28 AM
    I'm looking to swap to a v8 in my 64 dart, but want to keep the typewriter. 318's, etc. are not hard to come by, but always have the later 904. Can I convert a later 904 to pushbutton?
  2. Woods74
    Woods74 Broke Senior
    6,007
    217
    Aug 21, 2010
    Seattle, WA
    Local Time:
    1:28 AM
    Try it and see, do a write-up, this would be great!
  3. Thumpower
    133
    1
    May 4, 2011
    Ventura
    Local Time:
    1:28 AM
    I have a 64 dart w/slant I want to swap to v8. 318's etc. are not hard to find, but are always coupled to the later 904 - I want to keep my pushbuttons! Can this be done?
  4. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    40,936
    8605
    Oct 14, 2010
    Idaho
    Local Time:
    1:28 AM
    Been a long time since I've fiddled with a PB TF. Isn't the case different? Where does the "park" cable enter? Aren't there two cables?
  5. Darter6
    Darter6 Well-Known Member
    3,984
    1151
    Jan 16, 2008
    Nevada
    Local Time:
    1:28 AM
    Look up Imperial Services. They changed the name to American something-or other but I think it will link.Anyway Steve,the owner will rework your push buttons and makes a adapter for the transmission along with new cables to run the later torqueflite. I got a kit and cables to do this to a 65 cable column shift B body that he makes. We talked about doing my 64 Belvedere push button when the time came, so I know he has the stuff.
  6. VDART
    VDART Well-Known Member
    5,669
    44
    Jul 23, 2006
    heizer ks
    Local Time:
    3:28 AM
    you will need an adapter for the slant to v-8 mount. Lawrence
  7. C130 Chief
    C130 Chief Mechanical Genius
    3,011
    154
    Nov 23, 2005
    Boise, ID
    Local Time:
    2:28 AM
    Imperial Creations used to make an adapter cable IIRC. I heard that they don't sell direct anymore. Try Schumacher.
  8. RustyRatRod
    RustyRatRod Weenie idiot loser. FABO Gold Member
    57,403
    26886
    Jun 7, 2010
    Georgia
    Local Time:
    4:28 AM
    I don't know the answer to your question, but I know someone who does. Pat Blais.
    Pat Blais Transmissions
    Seattle, WA 98125 -
    Phone: (206) 365-1966
  9. TrailBeast
    TrailBeast Slightly Twisted Member
    20,434
    7346
    Mar 11, 2011
    Arizona
    Local Time:
    2:28 AM
    Yep, case is different.
  10. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    50,298
    15135
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    3:28 AM
  11. krazykuda
    50,298
    15135
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    3:28 AM
  12. dodgedartgt
    dodgedartgt Well-Known Member
    213
    5
    Dec 2, 2006
    Local Time:
    4:28 AM
    Easiest, least expensive route is to find a '64-65 V8 cable shift trans, or at least the transmission case.
    (Note: '64 was last year for push button shift, with '65 going to a column shift lever. However, the trans was still cable controlled in '65, just with the cables originating from the lower end of the steering column, or the floor shifter.
    '66 was the first year for the "hard" linkage.)
    Mike in FL
