Converter too close to housing?
Discussion in 'Transmission and Drivetrain Tech' started by doogievlg, Jul 11, 2018.
  1. doogievlg
    doogievlg Well-Known Member
    6,665
    1706
    Nov 13, 2007
    Amelia, Ohio
    Local Time:
    7:47 AM
    Got the converter installed but it is really close to the housing. Is this correct?
  2. pishta
    pishta I know I'm right....
    13,454
    3208
    Oct 13, 2004
    Tustin, CA
    View My Photos
    Local Time:
    4:47 AM
    looks good to me, I had one rubbing after the lower trans bell hit a curb. It cracked it and pushed it up about 1/8 inch and I heard this whining sound. I was young and poor so I just hit it back down with a hammer....It may be hanging ever so slightly when its not supported by the flex plate.
    • Like Like x 1
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      13,826
      1923
      Jan 16, 2005
      las vegas
      View My Photos
      Local Time:
      4:47 AM
      simple...spin it back n forth...should hear the hub clack against the pump telling you that it is engaged...
    • doogievlg
      6,665
      1706
      Nov 13, 2007
      Amelia, Ohio
      Local Time:
      7:47 AM
      I’m not sure I hear a clack but it can’t get it on any farther. It thumped down twice but I can still pull it off by pulling straight out.
    • 70aarcuda
      13,826
      1923
      Jan 16, 2005
      las vegas
      View My Photos
      Local Time:
      4:47 AM
      if it thumped down twice..should be engaged...
    • doogievlg
      6,665
      1706
      Nov 13, 2007
      Amelia, Ohio
      Local Time:
      7:47 AM
      Another dumb question but does this trans cross member go in with this “open” side facing the rear? Like the arrow would be pointing to the rear in this photo.
    • krazykuda
      krazykuda FABO Gold Member FABO Gold Member
      44,482
      9905
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      6:47 AM
      Yes, it takes two "thumps" for the converter to be fully seated... :thumbsup:
    • CudaFactHackJob
      CudaFactHackJob Well-Known Member
      170
      47
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      6:47 AM
      I do a lot of bench jobs for beginners to install and the double clack or thump method is a flirtation with disaster. I finally posted "Automatic Transmission Installation Instructions" on CL Inland Empire, Ca. In it I say to turn the converter so that one of the lugs is at the top. Then place a straightedge across the front and measure back to one of the side pads. Then place the straightedge across the back of the flex plate and measure to the block. The trans measurement should be at least 1/8' more than the motor measurement. Also to loosen the distributor cap and screw 2 bolts into the block that have had their heads cut off and ground to a point, or 2 screwed into the bottom trans holes that go thru the block from the front.
