[WANTED] Convertible Belt Molding Clips
picture? i have some if i understand what you are talking about. maybe 3 or 4
Sorry I don't have a photo available. But they fit A and B body rag tops. They attach to the sail panel on the belt line and have a hole in them for the boot snap to screw in and hold the molding in place. I believe the years are 1967-1969. My car is a 68 Barracuda convertible.
Don't the screws through the snaps hold the trim on? ( I have never had mine off)
The screws run thru the snaps into the clip. The clip is solid on the under side as to not tear the top material.
Are you talking the strip inside the car
or the strip outside the car.
The top does not attach to the outside snaps or strip in any way. The top is stappled to the backside of the inside strip, then the inside strip is bolted to the body (welded in, captive nuts)
Part# 384-37961, Rear Belt Retainers (set of 25), $115.00.....in stock and ready to ship
Part# 359-37960, Rear Belt Trim Retainer(EACH), $4.75, These "retainers" allow the screw studs to hold into the car after going through the sheetmetal of the car and are shaped like an "S". .....in stock and ready to ship
