Convertible top install
Convertible A-Body Mopar
  1. Dennis Gerard
    Dennis Gerard Well-Known Member
    293
    75
    May 7, 2017
    Florida/tenn
    Local Time:
    2:13 PM
    Convertible top install, Has anyone bought one of the tops from convertible top guys and installed it them selfs?
  2. billccm
    billccm Well-Known Member
    190
    138
    May 13, 2018
    Tucson
    Local Time:
    11:13 AM
    I've assisted on three convertible top installs. None of the cars were A body, and only one was a mopar (lebaron). All three cars the top install was almost exactly the same.
    Having said that it's a two or three man job. You've got to know when to finesse and when to manhandle. Air stapler is helpful.
    My two cents is to have expert help, or let an expert do it.
    • Agree Agree x 2
    • hoosierdaddy
      hoosierdaddy Well-Known Member
      468
      217
      Nov 13, 2008
      Central Indiana
      Local Time:
      2:13 PM
      First off I'm not knocking your abilities but you should really have professional install the top if you want it to look good . Secondly before you buy a top check with some local shops and make sure they'll install your top , a lot of shops will only install what they buy .
      • Agree Agree x 2
      • 65 Dartman
        65 Dartman FABO Gold Member FABO Gold Member
        12,595
        3999
        Sep 24, 2006
        Strasburg, VA
        Local Time:
        2:13 PM
        I forget where I got the top (it’s been 20 plus years) for a 65 Coronet ‘vert. I followed the info in the 65 FSM step by step and it turned out great- no wrinkles, puckers, etc. I did have to do some rust repair in the header bow that I found after removing the old too (again following the FSM).
      • belmateo
        belmateo Well-Known Member
        2,123
        344
        Mar 29, 2008
        Belmont, California
        Local Time:
        11:13 AM
        Yes, I bought from them and installed it myself. Are you putting on the car in your avatar? Mine was a 68 Dart which is much more difficult because of the two rear corner points and a glass rear window. There are many Youtube videos and the instruction book they send you is very helpful. A car that age will probably need new tacking strips. Most important, mark the centers on your rear bow, the body where the top meets at in front of the trunk, the front and rear of the new top and the header.
      • Russ Dyer
        Russ Dyer 69 barracuda convertable
        14
        15
        Jan 3, 2019
        Brooksville Florida
        Local Time:
        2:13 PM
        That’s one job I’m going to leave to the experts! It scares me
        • Like Like x 1
        • Matthias
          Matthias Member
          20
          13
          Mar 6, 2021
          Germany
          Local Time:
          8:13 PM
          How was the quality of the top? I look for a top for my 1967 Dart
        • belmateo
          2,123
          344
          Mar 29, 2008
          Belmont, California
          Local Time:
          11:13 AM
          Perfect, no issues
        • JimMac
          JimMac Well-Known Member
          122
          29
          Feb 26, 2015
          Campbell River B.C. Canad
          Local Time:
          11:13 AM
          I did it last year on my 65 Valiant. It worked out not bad but I did not have the old top. If you can use the old one to match up it would be easier. I have looked at some cars at car shows and they are no better than mine is some cases. If you take your time and follow the instructions you should be O.K.
        • cudajoedart
          cudajoedart Active Member
          40
          42
          Mar 5, 2021
          Connecticut
          Local Time:
          2:13 PM
        • cudajoedart
          40
          42
          Mar 5, 2021
          Connecticut
          Local Time:
          2:13 PM
          Almost all tops are the same I did one on my 66 dart and one on brothers 63 valiant,it is a two man job and as long as you follow the directions should not be an issue
          Joe
