Converting to 11" Rear Brakes
e50095
I know the existing e brake cables work in this upgrade, but do I also use the existing e brake lever and the piece that runs between the shoes just under the wheel cylinder, or are they different for 11" brakes vs 10?
You will need everything from the backing plate out for the 11 inch brakes.
You can buy the appropriate kits( springs,etc.).
If you're converting from stock A-body SBP brakes, you're going to need different axle shafts too.
