Flyinbrian72duster
Dart and duster
904 with 3:55 with 195/70/14 from what I've seen on a chart it should be a 39 tooth is that correct
I've seen GPS Speedometer apps free for the iPhone and Android. It's a good way to dial it in!Your tire should be 24.75" tall? If so you need a 37 tooth gear.
good point. Slapping forehead!You can change the tire diameter by changing the air pressure in it. But the real thing that matters is the tire's circumference. So weight on, or off, the tire won't matter.
