1. pete9857
    pete9857 Well-Known Member
    730
    60
    Aug 5, 2012
    cincinnati
    Local Time:
    10:51 PM
    Will these Cragars fit a 75 disc brake Dart? Is the hub size compatible?
  2. famous bob
    famous bob mopar misfit FABO Gold Member
    15,328
    5507
    Aug 14, 2011
    okla
    Local Time:
    9:51 PM
    Only if ur car is blue !
  3. pete9857
    730
    60
    Aug 5, 2012
    cincinnati
    Local Time:
    10:51 PM
    Dam, I guess I could paint it
    • Like Like x 1
    • Dusterdenovo
      Dusterdenovo Contentedly Old School
      946
      1772
      Dec 10, 2011
      British Columbia
      Local Time:
      7:51 PM
      Don't know if this helps, but I have those wheels on my 73 Duster - BBP, 15x6. I am running with the "Right Stuff" disc brake conversion setup their SKU MDC66SDS. I think the rotors are stock spec. No problems.
    • pete9857
      730
      60
      Aug 5, 2012
      cincinnati
      Local Time:
      10:51 PM
      Yes they fit, but I don't like the the lug nuts keeping the wheel centered. I called Cragar, they don't have a collar to make them fit snug on the hub. I'm going to look into maybe getting some made.
    • TrailBeast
      TrailBeast Slightly Twisted Member
      20,708
      7817
      Mar 11, 2011
      Arizona
      Local Time:
      7:51 PM
      Those are called Hub Centric Rings and I ordered mine online and they were a perfect fit.
      Problem is, I don't remember where I ordered them from.
      It was a place recommended by another member.
      Jegs carries them also.
      Detroit Wheels Hub Centric Rings | JEGS
    • pete9857
      730
      60
      Aug 5, 2012
      cincinnati
      Local Time:
      10:51 PM
      thank you
    • pete9857
      730
      60
      Aug 5, 2012
      cincinnati
      Local Time:
      10:51 PM
      no fitment for a 75 in there search engine. Ill try calling
    • pete9857
      730
      60
      Aug 5, 2012
      cincinnati
      Local Time:
      10:51 PM
      no one has any rings that big of OD, 90.68mm
