1. 512Stroker
    512Stroker We are all here because we are not all there.
    1,106
    775
    May 30, 2016
    Freedom, MO
    Local Time:
    7:28 PM
    I have a 67 Barracuda with a set of direct drilled Crager S/S wheels 5 on 4 mopar bolt pattern 7/16 -20 lug thread.
    My issue is when I torque the lugs to the specified 75 ft/lbs it bends the lug washer bad, even brand new Crager lug sets that I that just put on. It is like the washers a to soft. Is this normal/safe?
    Thanks in advance for your reply
    PS My old lugs/washers were bent just as bad I doubt they ever held torque.
  2. scott657
    scott657 Well-Known Member
    536
    268
    Dec 26, 2016
    Lancaster, Ca
    Local Time:
    5:28 PM
    aren't the seats conical on the direct drill? If so you wouldn't need the washers
    • Agree Agree x 1
    • 65-440
      65-440 Well-Known Member
      1,436
      204
      Apr 11, 2010
      va. beach, va
      Local Time:
      10:28 PM
      This .....
    • pomonamissel
      pomonamissel Well-Known Member
      1,693
      801
      May 21, 2015
      san jose , ca
      Local Time:
      7:28 PM
      early aftermarket rims crager american us indy all used shank type lug nuts with thin flatwashers . the washers are so the rims didn't get scared n chewed up for the lugnuts. yes the washer get bent by the lug hex . some have a deeper spot face for the washers to sit in , i've found that washer have two different od's 1 1/8 and 1 1/4 . the 1 1/8 bends up more then the larger ones . but an abody 4'' pattern is very tight on the center cone . could be part of the reason . putting some early vintage americans t70's14x6 3/4 , built special for the 4'' bc . lets see how it goes . just doing the noise like the 43ir its a 64 barracuda 15x8's steelies on the rear i built .
      • Like Like x 1
      • Thanks! Thanks! x 1
      • 512Stroker
        1,106
        775
        May 30, 2016
        Freedom, MO
        Local Time:
        7:28 PM
        The new ones are conical the old S/S are shank type with a washer.
      • rustycowll69
        rustycowll69 Well-Known Member
        2,100
        936
        Feb 19, 2016
        Pacific northwest
        Local Time:
        5:28 PM
        I know 75ftlbs doesn't sound like much nowadays, but oem was 55. Have you checked with Cragar?
        • Agree Agree x 1
        • 512Stroker
          1,106
          775
          May 30, 2016
          Freedom, MO
          Local Time:
          7:28 PM
          According to the Crager website the torque spec for 7/16 - 20 lug is 70 - 80 ft/lbs.
          • Agree Agree x 1
          • pomonamissel
            1,693
            801
            May 21, 2015
            san jose , ca
            Local Time:
            7:28 PM
            but is that for the shank washer type lugs as well . new stuff is different as you can read .
            • Like Like x 1
            • 512Stroker
              1,106
              775
              May 30, 2016
              Freedom, MO
              Local Time:
              7:28 PM
              Good question the website does not say any type. I will ask Crager and get back to ya.
            • rustycowll69
              2,100
              936
              Feb 19, 2016
              Pacific northwest
              Local Time:
              5:28 PM
              it wouldn't hurt to send then some pics of the wheel stud holes, lug nuts and distorted washers. Maybe they have not had any feedback and are unaware of a problem.
              So you mentioned the studs are 7/16" NF, but have you actually measured the drilled stud holes? How much bigger than the nut shanks are the stud holes in the wheels?
            • pomonamissel
              1,693
              801
              May 21, 2015
              san jose , ca
              Local Time:
              7:28 PM
              i run shank type with my americans , i never berry the lugs , armstrong tight . they should not come loose unless the lug holes are nice , slotted holes have an issue . the only issue shank type had was to long of a shank , would come to the part of the stud that flares out and flare itself would drag on the inside of the rim holes , shorting and counterslink the shanks threaded ends was the fit . and for to long of studs , top the tops off , but that more work that fixing the studs .
            • 4spdragtop
              4spdragtop Well-Known Member
              28,382
              8222
              Aug 28, 2009
              Wasting time here
              Local Time:
              7:28 PM
              I have shank style on my 67 with SS. I broke the damned nit "guessing" the torque.
              I went with factory spec and no issues. Obviously retorque after a short drive
              • Like Like x 1
              • 512Stroker
                1,106
                775
                May 30, 2016
                Freedom, MO
                Local Time:
                7:28 PM
                Can I assume you mean 55 ft/lb's as the factory spec? Or something else?
              • 4spdragtop
                28,382
                8222
                Aug 28, 2009
                Wasting time here
                Local Time:
                7:28 PM
                Yep, even my 69 fsm says 55. I think I torqued to 70 amd split the lug.
                Do so at your own risk tho. Lol I did and still here.
              • 512Stroker
                1,106
                775
                May 30, 2016
                Freedom, MO
                Local Time:
                7:28 PM
                Crager's customer service guy in CA recommended 65ft/lb's for all Crager 7/16 lugs.
