Crane SB Solid Roller cam FS
metallidart
member me?
Legendary Member
East Palestine, Ohio
I have a Crane Solid Roller Camshaft that I don't need anymore. Its new, been sitting a while. It is pn 698801, .630/.630 lift with 1.5 rockers, 260/266 @ .050, 292/298 adv. Good mid range torque and HP, rough idle, performance usage, oval track, bracket racing, auto trans w/ race converter, 11.5 to 12.5 compression ratio advised. RPM range is 3800-7600 (depending on your cubes). You have to use a bronze gear.
I was going to use it in my 422, but I am using Edelbrocks instead of Indy heads, and I'm just kind of toning down the engine a bit. I can get pics if you like, I don't have my camera with me right now. Summit wants $404.95, I don't. I'd like it, but I think $225 plus shipping sounds good. I just need to pay my gas bill.
Its located in East Palestine, OH 44413. Send me a pm!
Unless you like going in your motor all the time (cleaning, replacing parts), don't use it! Go order yourself one with a cast iron gear on it.
