Crank Shaft Conversion Pilot Reduction Sleeve
The Dart GT
1963 Dodge Dart GT Convertible
USA
I'm just posting this for future reference just incase someone might be looking for the crankshaft reduction collar for those 1967 or later crankshafts trying to mate with an earlier, smaller torque converter support counterbore. The size of the crankshaft bore increased in 1967 so the crank bore size needs to be reduced to mate properly to the earlier torque converter. This one I found on Amazon (believe it or not) has a tapered inside edge making it easier to mate with the torque converter counterbore. The sleeve has an OD = 1.807 and ID = 1.555 and fits perfectly.
Here's the link: https://www.amazon.com/Torque-Converter-Sleeve-Adapter-TX-17/dp/B0BZDQLVWF/?tag=fabo03-20
