1. dustya_383
    dustya_383 Well-Known Member
    1,160
    40
    Oct 7, 2009
    san Jose Ca
    Local Time:
    2:28 AM
    I was told that when switching from auto to stick, your crank needs to be drilled a certain way for the a833 to work is this true if so does anyone have a pic of the difference???? I also heard since I have a 68 383. Its actually drilled both for auto and manual is this also true?? Thanks
  2. perfacar
    perfacar Well-Known Member
    1,099
    289
    Mar 1, 2006
    renton,wa
    Local Time:
    2:28 AM
    hi the crank is drilled for both, except, the part for manual trans is not finish bored, if it was installed in an auomatic car. NAPA sells a bushing that fits the smaller hole. thats easier , than boring it out in a lathe. just food for thought
  3. dodgewade
    dodgewade Well-Known Member
    48
    1
    Dec 9, 2009
    Local Time:
    4:28 AM
    So you can buy the bushing, but still need to cut the shaft off about 5/8 or so?
  4. dodgewade
    48
    1
    Dec 9, 2009
    Local Time:
    4:28 AM
    So, you can buy the thinner bushing? But still need to cut the shaft off about 5/8"?
