KB9GIB
Can anyone show me how to use the Delphi crimpers? We bought them from American autowire I cannot find nothing on YouTube any help would be appreciate. KB9GIB thanks
Yes the "W" style crimps are non insulatedThose appear to be for non-insulated terminals.
Alan
American autoware usually gives a small baggie of practice pieces..Sit down with a few extra connectors and practice. Then try with some wire inserted.
I always start with a larger cavity and finish with the proper gauge one. You need to get the tabs starting to bend in the proper direction.American autoware usually gives a small baggie of practice pieces..
I find but sometimes pre-bending them just a slight to get them started with the tip of the pliers and then get them in the crimper kind of helps them go in the right direction...
Yup. We had similar terminals at work, for no10. I always just bent them a bit with needle nose. LOL, for those type, there WERE no larger diesI always start with a larger cavity and finish with the proper gauge one. You need to get the tabs starting to bend in the proper direction.
Just came across this one.
Its a Sargent 3182 CT. Looks like it crimps the insulation at the same time as the conductor.
Catalog state that its for terminals for 20 to 14 gage.
Maybe
A 18-20 ?
B 14-16 ?
C 12 ?
You'll have to see how specific terminals and wires actually fit. After you crimp, give it a tug. Shouldn't move.
TCT 1028. I bet I sold 2-300 of thoseHere is my Mac Tools pin connector crimper, but I have used it occasionally on auto connections. The rachet crimper is aircraft, it has a strain relief. That is for the plastic on your terminal, it helps support the wire against vibration breakage. Soldering, though I like it best, can be prone to breakage, where ever the solder stops, that is your weak point.
