Crimps in fuel line to carb
Fuel and Air Systems
  1. GoldSwinger71
    GoldSwinger71 FABO Gold Member FABO Gold Member
    47
    36
    Nov 16, 2019
    Minneapolis, MN
    Local Time:
    3:08 AM
    My 318 2bbl Dart has an (apparently?) 1 year only Rochester 2GV carb on top. I have an obviously sticky needle valve that's causing the engine to get gobs of fuel, so I started eyeballing taking it off to do a rebuild.
    The problem is, I looked at the hard line coming from the tank (on the passenger side), and it's got several kinks in it (4-5) as it comes up towards the carb.
    Is this something that would be worth it to cut out, flare it, put a union in, and make a new piece of hard line to the carb? Or should I just leave it be? As long as I can confirm that's a fuel source (there shouldn't be a return?) I could also use that as an excuse to put a fuel filter inline.
    I'm very new to non fuel-injected stuff, and to be completely honest, I'm trying to apply skills that I've observed from the family through some basic wrenching of my own.
    Thanks!
    Daniel
    • Like Like x 1
    • Dana67Dart
      Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
      3,525
      2084
      Jul 16, 2017
      Northern Colorado
      Local Time:
      2:08 AM
      You could do a flow test to see if the kinks are restrictive.
    • Cope
      Cope Fusing with fire
      3,956
      4553
      Oct 20, 2009
      San Jose, Ca.
      Local Time:
      3:08 AM
      Your second sentence answers your question. You have a stuck needle thats allowing to much fuel into the engine.
      Therefore the kinks in fuel line are not an issue. Your already getting more fuel than you can use?
      • Agree Agree x 2
      • Like Like x 1
      • 69conv
        69conv error 401 FABO Gold Member
        2,811
        2722
        Jan 27, 2013
        Motor City
        Local Time:
        3:08 AM
        And yes U need a fuel filter.
        • Agree Agree x 2
        • 1971swinger
          1971swinger Well-Known Member
          60
          26
          Mar 3, 2017
          25140 chippendale
          Local Time:
          4:08 AM
          I have a 71 dart swinger i also have the Rochester 2 barrel carburetor my car is air conditioning in my fuel filter is before the fuel pump because there's no room on the line to install one with the air conditioner there no problem with mine you're the first guy I heard that had that Rochester carburetor it's very rare good luck
          • Like Like x 1
          • Johnny Dart
            Johnny Dart Well-Known Member
            7,640
            1984
            Nov 30, 2006
            So Cal
            Local Time:
            1:08 AM
            I would fix both.
            You can get a new, pre-bent fuel line for $65.00
            No reason to run a 50yr old bent up fuel line. Inline Tube can set you up.
            www.inlinetube.com
          • TRWRacing
            TRWRacing Well-Known Member
            375
            57
            Nov 3, 2015
            Chicago
            Local Time:
            3:08 AM
            My 1971 Dodge Demon 318 had that carb it would bog at times coasting that ever so slightly getting back on the throttle. I learned 2 decades later that there was a TSB to enlarge the jets to fix it.
          • GoldSwinger71
            47
            36
            Nov 16, 2019
            Minneapolis, MN
            Local Time:
            3:08 AM
            I've continued to dig into this, I ordered a fuel pump to carb stainless line, but based on my initial look (haven't matched it in the garage yet) it might not have the fuel inlet at the same location on the 2GV carb? Does anyone have a picture handy of the fuel line from the pump to carb (regardless of the carb model) ?
          • Johnny Dart
            7,640
            1984
            Nov 30, 2006
            So Cal
            Local Time:
            1:08 AM
            Factory 4bbl fuel line.
            • Like Like x 2
            • RustyRatRod
              RustyRatRod Weenie idiot loser. FABO Gold Member
              58,502
              28916
              Jun 7, 2010
              Georgia
              Local Time:
              4:08 AM
            • GoldSwinger71
              47
              36
              Nov 16, 2019
              Minneapolis, MN
              Local Time:
              3:08 AM
              So after looking at mine, they spliced a fuel filter before the pump, and there's some janky stuff going on up to the Rochester 2GV. I see I'm going to be learning that bending and flare tool sooner rather than later.
              • Like Like x 1
              • Johnny Dart
                7,640
                1984
                Nov 30, 2006
                So Cal
                Local Time:
                1:08 AM
                Lol....Its all I got Rusty. :)
              • Johnny Dart
                7,640
                1984
                Nov 30, 2006
                So Cal
                Local Time:
                1:08 AM
                Time to shake the 2bbl, and put a 4bbl on.
              • krazykuda
                krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                51,699
                16351
                Aug 20, 2007
                Orland Park, IL
                Local Time:
                3:08 AM
                Kinks in the fuel line are flow restrictions... I would make a new line with clean bends...
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                41,710
                9362
                Oct 14, 2010
                Idaho
                Local Time:
                1:08 AM
                A couple of things.........an everyday filter before the pump may introduce too much restriction, as the pump is doing "it's best" under vacuum to start with. There are (exist) special low restriction filters designed for suction side use
                The other thing, is that you may have a lot of "crap" in the tank/ feed line that is causing the trouble, and the previous owner put a filter there to try and stop it.
                • Agree Agree x 1
                • AJ/FormS
                  AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                  17,553
                  5950
                  Jan 19, 2014
                  South-Central Manitoba,Canada, 900ftelevation
                  Local Time:
                  3:08 AM
                  You know how much fuel a stock 2bbl 318 is likely to require?
                  About a 3 cups per minute at between 4000 and 5000rpm, at WOT.
                  With 2.76 gears, this happens at ~50 mph in first gear. Nobody I know would ever do that to a streeter.
                  It will take you about 8 to 10 seconds to get to 50, burning an average of ~1.5 ounces per second at the very best it can do. You wanna guess how much gas is stored in that Rochester 2bbl?
                  I'll guess 3 to 4 ounces. Lets say the pump dies at WOT, and 3.5ounces is able to exit, that would be I'm guessing 4 to 5 seconds worth.
                  But at 1000rpm, in Drive/30mph, and cruising, say at 12 hp, you might be looking at 2 to 2.5 ounces per minute, so now, with no fuel coming into the bowl, you are good for almost 1.5 minutes of cruising.
                  The "kinks" would have to be pretty ugly to be a problem .
                  BTW; NEVER patch old fuel lines with compression fittings, especially on the suction side. Have you seen what that compression ring does to the line? If it sucks air, you will tear your hair out trying to figure it out. If it leaks raw gas........ maybe it will syphon all your gas out. But if it just empties the line, Yur in for a lotta cranking, and baaaack to hair pulling.
                  What about the pressure side? Well #1 yur gonna see it right away, and #2 if the engine is running with the hood up, chances are it will catch on fire right away, and you can file an insurance claim. Whatever the case, you can stop wondering why yur getting such rotten fuel mileage.lol
                • GoldSwinger71
                  47
                  36
                  Nov 16, 2019
                  Minneapolis, MN
                  Local Time:
                  3:08 AM
                  This spring I plan to drain the tank to see what lovely stuff comes out of it. I will also be replacing the fuel level sender (since the gauge doesn't work... might be the Instrument Voltage Regulator, replacing that first...) Yeah, some of it is purely cosmetic, but I'd rather have less of a patchwork of lines when it comes to fuel. I'll also be carrying a fire extinguisher with me... it's a habit from driving with tow straps, cold weather gear, jumper cables, etc.
