Crud on Side Marker inside Fender Well
Mopar Body and Trim
  1. 70DusterBob
    70DusterBob Well-Known Member
    567
    126
    Feb 20, 2016
    Texas
    Local Time:
    10:40 PM
    I cannot, for the life of me, figure out how to get the road grime off the side markers that accumulated for 45 years! I would like to get my side markers working, but they need new bulbs and I can't figure how to "Safely" remove all that crud that is on them.
    Any ideas?
    Thanks
  2. mycuda
    mycuda FABO Gold Member FABO Gold Member
    5,641
    2923
    Feb 15, 2011
    Chicago/ Metro
    Local Time:
    10:40 PM
    Probably amateur under coating restoration..........
    Seen it many times. Slowly turn fasteners and work it loose.........
    • Like Like x 1
    • ScampMike
      ScampMike Despicable Damn Yankee
      34,113
      8902
      Oct 26, 2015
      all Mopar driveway
      Local Time:
      11:40 PM
      assuming it is undercoating - a hair dryer on high (do not use a heat gun!) and a medium blade screw driver to clean/scrape the goo/crude - the heat will also make getting the nuts loose easier - carb cleaner to clean the tools later
      • Like Like x 1
      • 70DusterBob
        567
        126
        Feb 20, 2016
        Texas
        Local Time:
        10:40 PM
        Not sure it is undercoating. It seems like dirt that is compressed, big time. I "think" it is road grime from 45 years of driving. I will double check to see if it might be undercoating, but the car was not really worked on much before I got it. It sat for a number of years, but it seems like the must have driven it through a hundred mud puddles or something, lol?
        If it is dirt how could I get it off. I can't get to the nuts to turn them, they are buried in this stuff. ugh But the dirt is like rock or something now, very, very, vvvvvvvery hard.
      • ScampMike
        34,113
        8902
        Oct 26, 2015
        all Mopar driveway
        Local Time:
        11:40 PM
        medium wire brush - carefully
        • Like Like x 1
        • ScampMike
          34,113
          8902
          Oct 26, 2015
          all Mopar driveway
          Local Time:
          11:40 PM
          maybe get in there with some hot water and scotch-brite and see if the dirt comes away and what it leaves behind..
          • Like Like x 1
          • 70DusterBob
            567
            126
            Feb 20, 2016
            Texas
            Local Time:
            10:40 PM
            Yeah, a wire brush and/or scotch bright would work with water. Never thought of that.
            Thanks. I will try it in the morning.
          • Daves69
            Daves69 FABO Gold Member FABO Gold Member
            4,847
            2947
            Feb 20, 2011
            WestOfChi
            Local Time:
            10:40 PM
            You could do like the mining industry, take a core sample.
            Find a heavy area, and drill into it with a 1/8" bit at slow speed. See what comes out.
            Probably decades old hardened road tar.
