CT or Southern MA welders? Looking to have wheels narrowed.
North East
  1. MRGTX
    MRGTX Well-Known Member
    1,950
    761
    Sep 24, 2007
    CT, USA
    Local Time:
    5:06 PM
    Guys,
    Is anyone aware of a local welder who can modify aluminum wheels? I need to take a bit of metal out of a set of 15x8s to run on the front...looks like the going price for a job like this isn't cheap...hoping to at least avoid shipping and it's always best to support local businesses, IMO.
  2. kc0r8y
    kc0r8y Well-Known Member
    253
    73
    Aug 25, 2015
    Connecticut
    Local Time:
    6:06 PM
    • Thanks! Thanks! x 1
    • MRGTX
      1,950
      761
      Sep 24, 2007
      CT, USA
      Local Time:
      5:06 PM
      Thanks but they don't do wheels...
      Anyone else?
    • mischiefdart
      mischiefdart Well-Known Member
      1,431
      72
      Jan 30, 2010
      Newark DE
      Local Time:
      5:06 PM
      What kind of wheels do you have? Pics?
    • MRGTX
      1,950
      761
      Sep 24, 2007
      CT, USA
      Local Time:
      5:06 PM
      Rota RKR. They just don't make them in 15x7. I tried to pick an offset that would clear the fender for the front...which it did but as I was warned, 15x8" wide wheels are also likely to contact the control arm...which they do, even with a spacer.
    • mischiefdart
      1,431
      72
      Jan 30, 2010
      Newark DE
      Local Time:
      5:06 PM
      Sweet wheels! I like the old minilites and panasports. Perhaps you could modify your steering stops to keep them from rubbing on hard turns. Also maybe an inner rim half from a three piece wheel might work. Machine off the inner bead down to the center and add the bolt pattern for the inner half.
      • MRGTX
        1,950
        761
        Sep 24, 2007
        CT, USA
        Local Time:
        5:06 PM
        I'll look into the steering stop idea...thanks.
        As for the inner rim half--do you mean a spacer? If so, I think I've exhausted that option. :/
      • mischiefdart
        1,431
        72
        Jan 30, 2010
        Newark DE
        Local Time:
        5:06 PM
        Not a spacer. It would be like a centerline autodrag but from the tire bead to the riveted part. That way you could just bolt it to the wheel and not have to deal with welding. I am not a fan of welds on aluminum wheels. All good aluminum wheels are either forged or spun and heat treated. Welding is like plain cast aluminum.
        • bigus1949
          bigus1949 Well-Known Member
          1,066
          34
          Aug 5, 2010
          manchester, ct
          Local Time:
          5:06 PM
          contact richard at truck toys in rockyhill , ct. he may be able to help you narrow your wheels. tell him mike elliott from the gear head mafia car club of ct sent you. good luck.
          • MRGTX
            1,950
            761
            Sep 24, 2007
            CT, USA
            Local Time:
            5:06 PM
            Thanks...I made a few calls but no one could do the job around here. I already shipped them to Michigan. I will keep Richard in mind for the next time!
          • MRGTX
            1,950
            761
            Sep 24, 2007
            CT, USA
            Local Time:
            5:06 PM
            So far, so good
          • mischiefdart
            1,431
            72
            Jan 30, 2010
            Newark DE
            Local Time:
            5:06 PM
            I hope they work well for you.
            • jamesdart
              jamesdart Well-Known Member
              1,519
              47
              May 6, 2007
              Local Time:
              5:06 PM
              Too late but there's a guy in nj that I had narrow some steel wheels. He used to do aluminum and work on motorcycle wheels too. Looks like they did a nice job.
              • MRGTX
                1,950
                761
                Sep 24, 2007
                CT, USA
                Local Time:
                5:06 PM
                Thanks...do you remember his name? This could come in handy in the future, particularly with a good recommendation like yours.
              • jamesdart
                1,519
                47
                May 6, 2007
                Local Time:
                5:06 PM
                WheelWorks on rt130 in Burlington nj. I think his name was Tim.
