BKCowGod
My '65 Dart has come a long way. I have added the following:
The stereo is wired directly to the battery, the headlights and fan are wired to the battery through relays. The alternator it came with appears to be original, or salvaged from the Edmund Fitzgerald some time ago, and it has been showing some significant voltage drop even with only the stereo on. At idle I have been around 12.5, rarely above 13. Today I had to turn off the a/c and the electric fan because even at cruise it was dropping below 12 on the gauge.
Stopped by O'Reilly's and picked up one of the remans rated at 55a. I know the remans are crap, but for the ability to test the component and have a good return policy and instant gratification it's hard to beat.
With the new alt, it is idling right at "C" on the ammeter and a hair above 13v with only the stereo. Revving the engine moves me 1/4" above C and moves the volt meter up to 14 or so. I felt all relevant wires. Warm but not hot, but I also didn't drive it on the freeway for an extended period of time and the battery was probably somewhat discharged as a result of the above described voltage drops.
That was really long winded, but there are so many posts about ammeters that contradict each other that I wanted to provide as much data as possible about my setup.
Now....
1) I wish to keep the ammeter for now (mainly because I don't want to remove the cluster again). How long until I catch on fire? I know the '65 had magic wiring, but how magic is it?
2) Can I run a nice thick wire from the alternator to the positive terminal on the starter motor and make everything better? Will the ammeter still do anything if I do this?
3) I do have a spare bottle of Lucas smoke from my Land Rovers and my MG - is it compatible?
- Mopar electric ignition
- Solid state voltage regulator
- A relatively small stereo (10 amps)
- H4 headlights (9 amps)
- Electric fan (8 amps)
- Volt gauge wired directly to battery
Now....
