Custom Dash Discussion/show/tell
Mopar Interiors
  1. wes beem
    wes beem Well-Known Member
    551
    262
    Apr 16, 2017
    ohio
    Local Time:
    10:05 PM
    Hey guys, I'm currently working on a custom gauge cluster for my 70 Dart. It's not looking pretty right now since today was my first day working on it, but I ran into a little issue. My Gauges are pretty large and there's really no room to mount the Headlight switch and Whiper switch in the factory location. The aftermarket tilt steering collumn I have also doesn't have a key so i have to mount that somewhere too. The car is kind of a restomod so if your a Purist this post will probably just make you mad but I'm looking for ideas on how to set up my dash overall. The cluster is pretty set in stone. Ill be having to fabricate a center panel as the cars getting a modern radio. There will be no heater controls whatsoever as the car wont be running Heat/AC so I have a lot of real-estate to do something cool with.
    So I'm looking for ideas and photos of what some of y'all have done to yours. I don't want it to umm... racecarish. It is a street car so I do want a clean finished look to it while tiptoeing the line between classic and modern aesthetics.
    52729370_10210568124399302_6112444739515056128_n.jpg 52602769_10210568124679309_1460608804163944448_n.jpg 52514061_10210568124919315_4438370816584843264_n.jpg 52883780_10210568125159321_1190744919350706176_n.jpg 5148_1_lg.jpg
    • Like Like x 3
    • Matts440
      Matts440 Well-Known Member
      2,704
      1537
      Apr 11, 2014
      Nampa, Idaho
      Local Time:
      9:05 PM
      Any room between those lower gaps to mount the two switches?, might need to angle the back part of the switches but it's an idea. Here's a picture of my dash I had made.
      • Like Like x 3
      • wes beem
        551
        262
        Apr 16, 2017
        ohio
        Local Time:
        10:05 PM
        off topic but i love that center console with drink holders
      • Matts440
        2,704
        1537
        Apr 11, 2014
        Nampa, Idaho
        Local Time:
        9:05 PM
        Thank you, just got done getting it all done. I actually have my stereo mounted on top of my console.
      • pauly v.100
        pauly v.100 Well-Known Member
        2,756
        181
        Sep 28, 2005
        honolulu, hi.
        Local Time:
        5:05 PM
        Mine..
        • Like Like x 5
        • pauly v.100
          2,756
          181
          Sep 28, 2005
          honolulu, hi.
          Local Time:
          5:05 PM
          and another..
          • Like Like x 3
          • wes beem
            551
            262
            Apr 16, 2017
            ohio
            Local Time:
            10:05 PM
          • wes beem
            551
            262
            Apr 16, 2017
            ohio
            Local Time:
            10:05 PM
            What kind of switches are those
          • pauly v.100
            2,756
            181
            Sep 28, 2005
            honolulu, hi.
            Local Time:
            5:05 PM
            The headlight switch is a GM based universal, the wiper switch is original.
            At the time, i had the high beam indicator wires crossed so it was on for the low beams.
          • 67Dart273
            67Dart273 FABO Gold Member FABO Gold Member
            52,471
            21620
            Oct 14, 2010
            Idaho
            Local Time:
            7:05 PM
            Problem with the Darts is that the Valiant style cluster is WAY easier to customize. I've even thought of dropping the later "flat" style dash cluster/ frame into mine, not sure to do about ignition switch.
          • 5.7 hemi
            5.7 hemi FABO Gold Member FABO Gold Member
            3,547
            3137
            Apr 18, 2009
            Local Time:
            9:05 PM
            Dakota Digital VHX in my 69’ Dart GT. Had to do some cutting and welding, but definitely worth it.
            • Like Like x 2
            • meathead66
              meathead66 Mod Top
              760
              414
              Jan 19, 2008
              Tinley Park Illinois
              Local Time:
              9:05 PM
              Mine is very similar to Matts440 however wish I'd have cut out a provision for a radio. Guess that could still be done down the road. Seems like these projects are never done.
              • Like Like x 2
              • Matts440
                2,704
                1537
                Apr 11, 2014
                Nampa, Idaho
                Local Time:
                9:05 PM
                ^^^ that's so true. I actually mounted a radio on top of my console to keep the dash clean, you have less room then I do lol.
              • 74 GoldenDuster
                74 GoldenDuster Member
                19
                8
                Mar 21, 2016
                Bakersfield, CA
                Local Time:
                7:05 PM
              • 74 GoldenDuster
                19
                8
                Mar 21, 2016
                Bakersfield, CA
                Local Time:
                7:05 PM
                Here's a view of the dash I made. I have 7 gauges, lights, wipers, L&R turn signals, Hi Beam light , parking brake light, oil pressure light, and windshield spray button. 100_2080.JPG
                The head light switch is upper left, wipers lower right, windshield washer button lower left between Volt & Vac, oil & p/b lights above vacuum, L turn-Hi beam- R turn lights centered above tach & speedo. This whole unit slips into space of bezel & instrument cluster. It's upholstered sheet metal, punched holes for gauges, very tight fit. With a little more squeezing, I could possible get five 2" gauges instead of the 4 with the 1 3/4".
              • Jlcaptain24
                Jlcaptain24 Well-Known Member
                474
                126
                Apr 21, 2012
                Fort Worth
                Local Time:
                9:05 PM
              • wes beem
                551
                262
                Apr 16, 2017
                ohio
                Local Time:
                10:05 PM
                Very cool guys!
              • MonkeyMadness
                MonkeyMadness Well-Known Member
                1,147
                1410
                Jun 13, 2016
                Yorba Linda California
                Local Time:
                7:05 PM
                It's not a Dart but any input is better then no input. Right?
                I went with Dakota Digital... Told them what I needed and they were able to make it ALL work...
                20180910_114843.jpg 20190121_110020.jpg 20190121_105928.jpg 20190121_104746.jpg
                • Like Like x 1
                • 75slant6
                  75slant6 Well-Known Member
                  5,785
                  2428
                  May 15, 2011
                  Russellville, ky
                  Local Time:
                  9:05 PM
