timk225
I am working on my 1973 Plymouth Duster, and wanted to make better use of the rear wheel wells, and eliminate the "fat butt woman in tight dress from the rear" look of the rear wheel track being too narrow because Chrysler was too cheap to make the axle a little wider.
So I got a set of 30 mm (1.18") wheel spacers on Summit Racing, and a set of Milodon #86165 3" wheel studs. Supposed to be for a Dana 60. Supposed to fit. Not quite.
I was working on the car today, and brought my vernier caliper to take some exact measurements. The package for the wheel studs claim the knurl area is .675". But I measured 0.685" across the knurls. And even worse, one of the OEM wheel studs that I tapped out of an axle shaft only measured 0.665" across the knurls. So I need to turn them down a bit, probably by chucking them up in a drill and spinning them while holding a file against them. I really need access to a lathe.
Then there's the issue of the stud length. My lug nuts are the closed end type to look right with the Rallye wheels. They would bottom out at 19 turns onto the wheel studs. With the OEM wheel studs, they are turning 9-10 turns onto the studs when the wheel is on tight. I think the lug nuts will bottom out on a 3" stud before tightening down the wheel properly. So I think I need to trim them to about 2.70", give or take 0.10". 5 threads are about 1/4" on these lugs, which are 1/2-20.
Anyone ever have to make modifications to new wheel studs like this? I pulled the axle shafts out of the 7-1/4" today to get new wheel bearings, so this is my chance.
