cutting fibergass hole
rigger3006
north america
just got pro stock scoop from speedway, need to cut opening, any thoughts or tips to help me not screw up, it cost me a lot of money to get it up to the great white north
Tungsten carbide jig saw blades. It looks like grit from 36 grit paper glued to the blade.
Lay masking tape down before cutting, #1 to prevent strands from splitting out away from cut, and #2 to prevent scratches on gelcoat from saw.
i have always used my angle grinder and cut off wheels. or even my dremel for tight stuff. I also like to drill holes at the corners and connect the dots. a round hole is less likely to start a crack then a sharp square corner. as said. use masking tape. 2 layers min. if your going to use any tool that has a base that rides on the hood while cutting (like jig saw) use 3-4 layers of tape so the tool base dont gouge or scratch the gel coat. a foam sanding block will dress the edges nicely. id use 120 grit.
