cutting up 74 dodge dart
340duster340
long island NY
cutting up this weekend ... 74 dart 2 door. if you want something its cheap. i will be cutting it up anyways car is moth eaten, but here is a list of what is still usable.
- doors (clean straight and rust free) 75 each
- fire wall w/ AC provisions
- inner fender walls
- rad support for larger ac radiator (banged in 1 corner but fixable) 100
- maybe some parts of the front frame rails.
sorry no shipping. let me know if you can use anything, prices are CHEAP except for the doors and rad support which are priced above.
i need a power brake booster, master cylinder and bracket for on the firewall. i will need it shipped also if you can do that. thanks,mike.
How are the door jamb lock pillars? I need both sides.
i posted an add looking for a 74 dart tail light for the left side and then seen this. do you have one that dose not have the filler panel between the tail lights?
how much for the bracket you have pictured there? also the booster in the picture, is it no good? i will need it shipped to 17813. thanks,mike.
How is the interior? I could use the plastic A-pillar pieces, and the similar pieces that go around the inside of the ceiling.
